Help, Tuner Installed Wrong? - Mustang Evolution
Old 10-07-2011, 05:18 PM   #1
xhgwx's Avatar
Hey everyone,
This is my first post on this mustang forums, but today I installed a custom tuned chip by Bama into my v6 2003 Mustang, and I'm not feeling much of a gain, I also have a BBK intake, any ideas?
xhgwx is offline   Reply With Quote
Old 10-07-2011, 06:14 PM   #2
98projectpony's Avatar
The only thing I can think of is unhook the battery take the chip out and try re installing it however the company tells you ...but thats just me one of these other guy might know something better
98projectpony is offline   Reply With Quote
Old 10-07-2011, 06:36 PM   #3
xhgwx's Avatar
Thanks for your input, I'm going to retake it out tomorrow and reinstall it. I cleaned it well and installed it step by step, I feel a little but that could just be me thinking I feel it.
Old 10-07-2011, 06:44 PM   #4
deadsp0t's Avatar
We were just discussing this in another thread. Performance gains will be minimal unless you have alot of mods, or a power adder. If your car is an automatic you should notice a difference in the shift points, and shift firmness. In the other thread someone said you may only see a few horsepower and a few ft/lbs of TQ.
---------- Post added at 08:44 PM ---------- Previous post was at 08:42 PM ----------
The title to the thread is 'programer performance' check it out.
That's unimpressive
Old 10-07-2011, 06:50 PM   #5
Lol yea I started that thread haha wanted to get more info on tuners and programmers before I bought one
Old 10-07-2011, 07:16 PM   #6
deadsp0t's Avatar
You bought used or new?
That's unimpressive
Old 10-07-2011, 11:30 PM   #7
xhgwx's Avatar
I didn't really notice a difference in shift points, but I did notice one in shift firmness, I can also feel more pull(Torque) through my power band but it's not drastic but it's not too little that you don't notice. Just not as good as some of the reviews I've read on it, but those people could have also had more mods, I plan to do a windstar ported lower and upper intake along with a BBK throttle body and which to a K&N CAI. After that I wanna do a UDP aluminum drive shaft posi with 4.10 gears and a 100 shot of nitrous. Then when it comes for the time to rebuild the engine I'll acid dip it and have it bored out to a 4.2L bore(can't remember the numbers on that) add forged pistons, a custom ground cam, and polished and ported heads, also changing rods and springs also ECT. Sound good to you?
Old 10-08-2011, 06:56 AM   #8
kickerofdoom's Avatar
Which tune u use
Old 10-08-2011, 07:24 AM   #9
xhgwx's Avatar
91 Octane Race tune, set up with a BBK CAI and I have some wider tires than stock.
Old 10-08-2011, 07:29 AM   #10
You feel alittle difference not Much but there
Old 10-08-2011, 08:13 AM   #11
xhgwx's Avatar
Now it's starting and then it will buzz and die?
Old 10-08-2011, 08:55 AM   #12
deadsp0t's Avatar
What do you mean 'buzz'?
That's unimpressive
Old 10-08-2011, 07:11 PM   #13
xhgwx's Avatar
Like a humming sound think of a bee sound but much louder.
Old 10-08-2011, 08:07 PM   #14
deadsp0t's Avatar
You might want to call the shop you bought it from..
That's unimpressive
Old 10-08-2011, 08:17 PM   #15
xhgwx's Avatar
Ok thank you
Old 10-09-2011, 12:20 AM   #16
xhgwx's Avatar
It sounds like the sound when it try to turn over the car and the battery is to low and it just clicks, but the battery is charger and the car turns over but the second I put it in reverse it makes the noise and dies, I'm going to go out tomorrow and retighten the wires on my battery. Maybe one of them came loose? I'll tell you what I find out. Also would you happen to know how I could tighten my throttle control string? My RPMS are idling very low at like .5 RPMs and I wanna get it to idle at 1-1.5
Old 10-09-2011, 01:46 PM   #17
deadsp0t's Avatar
If it's idling at 500-600rpms that's where it's supposed be at.
That's unimpressive
Old 10-09-2011, 04:59 PM   #18
ForsakenProto's Avatar
I wonder somehow the tune cause his car not to recognize the chip in his key, which would explain it turning over, but cutting off whenever he tried to drive it.
ForsakenProto is offline   Reply With Quote
Old 10-09-2011, 05:48 PM   #19
xhgwx's Avatar
Just reinstalled it I'll tell ya how it goes
---------- Post added at 05:48 PM ---------- Previous post was at 05:42 PM ----------
Started right up, and ran, I cleaned it extra good this time, can't tell if I got any power gains but it is raining here so I can't do much with out fish tailing
Old 10-10-2011, 07:14 PM   #20
deadsp0t's Avatar
Any luck with it today???
That's unimpressive
Old 10-10-2011, 07:15 PM   #21
xhgwx's Avatar
Runs fine, can't feel Amy power gains but it's running fine.
Old 10-10-2011, 07:23 PM   #22
deadsp0t's Avatar
That's half the battle anyway. Think I read a post something like 15hp and down is really hard to feel.
That's unimpressive
Old 10-10-2011, 07:24 PM   #23
xhgwx's Avatar
When I installed my CAI I gained 5-10 and I could feel it and I could feel it pull me off the line at a stop light.
Old 10-10-2011, 07:26 PM   #24
Yea the same here when I got my cai but now I'm looking to get a bbk underdrive pulley witch "should" give me another 10 hopefully
Old 10-10-2011, 07:42 PM   #25
xhgwx's Avatar
I'm wanting to do a windstar manifold and BBK throttle body next then get my chip retuned. I also want a different CAI right now I have the American muscle one, I want the K&N. I have a sound system that runs 800 watts so idk if my car would run well with UDPs but I defiantly wanna do true dual SLP exhaust, I hope to make 240-260hp and 250-280 torque with bolt ones but idk the possibility of that. Then I wanna add some nitrous(100 shot) for short term goals
---------- Post added at 07:42 PM ---------- Previous post was at 07:37 PM ----------
I'll post my goals everything from performance to handling to looks.
2003 V6 Mustang Project
193 Horsepower@5,500 RPM
228 LB-FT@2,800 RPM
Performance:
K&N CAI
SLP Loudmouth Exhaust
Custom Tuning Chip - DONE
Throttle Body BBK
Rear End Gears 4.10
Speedometer Recalibration Tool
T-Lok Ford Racing
Mac Long Tube Headers
Supercharger
Windstar Manifold
Super Six Motorsport Stroker Kit
Aluminum Drive Shaft
Drive Shaft Safety Loop
Aluminum/Lightweight Flywheel
Performance Spark Plugs
Under Drive Pulley
Nitrous Kit
Exterior:
Shorty Antenna
Raxiom Smoked Headlights
FR500 Wheels
Cobra Fog Lights
Sequential Tail Light Kit
Raxiom Smoked Tail Lights
Mustang Window Decal
CoverCraft Car Cover
Exterior Black Out Kit
Black Acorn Lug Nuts
Cobra R Center Cap
Cobra Valve Stem Caps
Grill Kit
Black Out Light Covers
Kaenen 1995 Cobra R Hood
Quarter Window Louvers
Rear Window Louver
Steeda Race Wing
Tail Light Black Out Covers
Wheels
Silver GT500 Decal 10 Inch
Silver Hash Marks
Lamborghini Doors
Window Tinting
Side Louvers
Repaint
Cobra R Body Kit
Front Fender Scoops
Chin Spoiler
Caliper Covers
Cobra Grill Emblem
Cobra Fender Emblems
Cobra R Emblem
Interior:
Leather Shifter Boot(Found a way to make the auto look like a stick)
Door Lock Bezels
Headlight Knob Bezel
Coin Holder Delete
Shifter Bezel
Window Switch Kit
Interior Chrome Door Handles
Chrome Automatic Shifter
Chrome Cup Holder
Cup Holder Bezel
Cigarette Lighter Delete
Chrome Coat Hooks
Cobra Floor Mats
Petal Covers
Trim Kit Carbon Fiber Black
New Carpet
Seat Upholstery
Stereo
Custom Sub Box
Custom Truck Lid Carpet and New Trunk Cobra Mat
Chrome Speaker Cover
Chrome Door Sills
Chrome Ring Gauge
Maintenance:
K&N Oil Filter
Handling:
H&R Super Sport Springs
Polyurethane Spring Isolators
Steeda Bumpsteer Kit
Steeda Caster Camber Plates
Tokico D-Spec Struts & Shocks
Black Strut Tower Brace
Eibach Anti-Roll Sway Bar Kit
Hawk Track Brake Pads
DBA Cross-Drilled/Power Slotted Rotors
Stainless Steel Brake Lines
Old 10-10-2011, 07:46 PM   #26
That sounds good my plans are to get a throttle body, a ram air intake, true dule exhuast with flowmaster super 44, underdrive pulley, racing spark plugs and racing coils, handheld custom tuner, thats the bolt on I also want 4.10 gears and rims, lowering springs but all this is over an 3 or 3 n half year plan
Old 10-10-2011, 07:49 PM   #27
xhgwx's Avatar
Mines a several year plan, I need a job ATM, so I slowly put back money towards the car, I'll be turning mine into a show car as you can tell probably and hopefully I can get 11-12second 1/4 mile with the engine rebuild.
Old 10-10-2011, 07:51 PM   #28
Lol I guess its just a mustang thing to want yours to be the best, fastest, and most custom haha im totally that way about my car ...so many things so little time
Old 10-10-2011, 07:54 PM   #29
xhgwx's Avatar
I wanna get atleast one of every body style, I wanna get a foxbody next I freaking love those
Old 10-11-2011, 08:17 AM   #30
Re: Help, Tuner Installed Wrong?
you can dyno before/after
did you go with a higher octane tune (most of the power would come from this as the timing would be advanced)
Old 10-11-2011, 08:28 AM   #31
xhgwx's Avatar
Yes, 91 octane
Old 10-11-2011, 08:31 AM   #32
you can have them resend a tune for you~ not sure if there is an all or nothing on uploading of the tune of if there is a way to validate it~ you can ask them.
Old 10-11-2011, 09:58 AM   #33
xhgwx's Avatar
I bought the chip from American Muscle, so I get free tunes for life, I would have to send the chip in though.
Old 10-11-2011, 03:54 PM   #34
xhgwx's Avatar
Car ran fine today, I dont feel anything in difference not even seeing a MPG change, nothing, kind of pissed off that I bought the product.
1994-1995 sct tuner f/s deadsp0t Mustang Parts for Sale and Wanted 1 10-03-2011 12:48 PM
94-95 Superchips Tuner deadsp0t 1979-1995 Mustang GT 23 09-15-2011 12:14 PM
2011-2012 v6 MT with tuner...... DannyDoright 2011-2014 V6 Mustang 8 08-21-2011 03:33 PM
suspension is finally installed! tigercrazy718 2005-2010 Mustang GT 8 08-18-2011 11:09 PM
Pros and Cons of SCT Tuner 2011Rushracing 2011-2014 V6 Mustang 5 08-18-2011 05:59 PM
03:32 AM
