After market underdrive pulley - Mustang Evolution
Old 10-09-2011, 01:16 PM   #1
98projectpony's Avatar
I'm thinking about buying an aftermarket underdrive pulley for my v6 98 w/cai the website I'm getting them from is american muscle and there bbk they say you can get 15 extra hp but from yall that have them whats the real number of hp you gain? And is there another tune up you would suggest
98projectpony is offline   Reply With Quote
Old 10-10-2011, 02:18 PM   #2
Blackheart4355's Avatar
I'd be surprised if you got thatmuch...maybe 10 is more like it
Blackheart4355 is offline   Reply With Quote
Old 10-10-2011, 02:44 PM   #3
Re: After market underdrive pulley
if its 25% underdrive you should get around 5-7rwhp (around 10 at the motor~) not a bad mod and may help gas mileage a bit but dont do it if you have a stereo system as it slows down the belt drive and alternator.
see if it comes with a harmonic balancer or just the pulley, if its just the pulley its MUCH easier to install than with the balancer (need impact gun to install it)
Old 10-10-2011, 04:42 PM   #4
Well I have access to an impactor and much other tools so thats not a worry
Old 10-10-2011, 07:13 PM   #5
TaylorF25's Avatar
Well I have an 03 v6 with one 12in sub and a single amp running the sub. So your saying that I shouldn't upgrade my underdrive pulley? I was thinking about it
TaylorF25 is offline   Reply With Quote
Old 10-10-2011, 07:18 PM   #6
Well I'm not sure but the bbk pulleys I'm getting says as long as you unhook the battery when installing then rehook after done then it resets its self to equal out the power so you dont lose any power but thats just what people and bbk says could just be trying to get you to buy but idk. I know I'm still going to buy them
Old 10-11-2011, 04:59 AM   #7
TaylorF25's Avatar
After you do the install and run it can you send me a pm just as a review? I've been wanting to upgrade mine as well
Old 10-11-2011, 06:28 AM   #8
kickerofdoom's Avatar
I heard they make a difference but for the little power I rather not do it. Better to add a Windstar intake. Add drag wheels
Old 10-11-2011, 08:29 AM   #9
you MAY have issues with your car if you have a system at low rpms~ not always just an FYI, sitting still will cause the battery to drain and the lights may dim a bit~ just part of it. I had a system and an underdrive pulley for a while, not a huge deal just something to think about.
Old 10-17-2011, 12:19 PM   #10
Ghostedmind's Avatar
Will other pulley kits fit on it or do you have to find one specific to the V6 because i cant seem to find one for the V6 on AM....LMR has one but its like $240
Old 10-17-2011, 12:23 PM   #11
for 99+ V6's the harmonic balancer and pulley are made together so you will need one specific to your car
ASP used to make them~ not sure who carries them now. Also note in 00-01 they swapped up harmonic balancers so make SURE you get the right one (notch in it or not you can look at yours and see)
Old 10-17-2011, 12:28 PM   #12
well i have an 04... so i know i need the one without the notch. I'll look at ASP i hadnt seen one from them
Old 10-17-2011, 04:30 PM   #13
Las0mbra's Avatar
Steeda makes the best quality ones. Check out their site:
Idler pulley jwhayne0001 1979-1995 Mustang GT 10 08-25-2011 04:48 PM
underdrive pulley kickerofdoom Pre-2005 V6 Mustang 6 08-09-2011 03:57 PM
Underdrive question?? GTdevildriver 1996-2004 Mustang GT 5 08-04-2011 09:18 AM
UD pulley kits t0t4lbl4ck0ut General Car Discussion 3 07-09-2011 09:02 AM
Water pump pulley Carlos92 Pre-2005 V6 Mustang 6 07-04-2011 07:55 PM
05:55 AM
