Annoying squeeking sound - Mustang Evolution
Old 10-11-2011, 11:24 AM   #1
PonyBoyV6's Avatar
Started a few days ago, the loudest, most obnoxious squeek coming from the engine bay. My dad thought it was an idler pully? Going bad, so he replaced that. Ran the car a couple minutes, no squeek. This morning on my way to school, squeek is back. ): any ideas on how to stop this annoying sound? Maybe a different pully gone bad? Any suggestions on how to check would be appreciated.
PonyBoyV6 is offline   Reply With Quote
Old 10-11-2011, 01:13 PM   #2
Otlaw80's Avatar
Did you change the belt when u did pulley?
Old 10-11-2011, 01:38 PM   #3
PonyBoyV6's Avatar
I did not, but the belt looked pretty good when we looked at it. No dry rot or anything.
Old 10-11-2011, 03:01 PM   #4
1988_gt_5.0's Avatar
Re: Annoying squeeking sound
i had the same problem on my '99 mustang i changed the water pump and a new belt hasn't squeaked since.
1988_gt_5.0 is offline   Reply With Quote
Old 10-11-2011, 03:33 PM   #5
jhagan1980's Avatar
Take the belt off and spin the pulleys by hand. If any feel rough it could be your problem.
jhagan1980 is offline   Reply With Quote
Old 10-11-2011, 07:57 PM   #6
Otlaw80's Avatar
Thats the best advice at this point. However, just to make sure its not your belt, start it up, and while its squeeling spray some water on the belt from a spray bottle. If it stops, then you need to replace your belt.
Old 10-14-2011, 08:04 PM   #7
PonyBoyV6's Avatar
Just replaced the belt, took it for atest drive, went about a block and it started sqeaking/ grinding again. Most frustrating thing ever.
Old 10-15-2011, 12:34 AM   #8
Did u check ALL the puies by hand while the bet was off?
---------- Post added at 10:34 PM ---------- Previous post was at 10:33 PM ----------
*pullyes
Old 10-15-2011, 12:46 AM   #9
PonyBoyV6's Avatar
My dad figured it was the belt, but it was not. But hes going to check them all out tomorrow.
Old 10-15-2011, 12:48 AM   #10
Cool all u need to do is turn the pulys by hand if they ruff or loose thats ur problem
Old 10-15-2011, 09:28 PM   #11
PonyBoyV6's Avatar
Turned the pullies, none of them really felt bad. I dunno if i should take it to a shop and let them figure out what it is. They'd probably charge me out the ***.
Old 10-16-2011, 02:32 AM   #12
If ur gonna take it to a shop make sure u go to a ford specialist ateast its worth ur $$$
---------- Post added at 12:32 AM ---------- Previous post was at 12:31 AM ----------
Really felt bad means it can squeek bad ur not supposed to feel any roughness or it being loose
Old 10-16-2011, 08:42 AM   #13
deadsp0t's Avatar
Tensioner, or AC compressor. Mine was squeaking a couple days before it locked up and flooded the car with smoke off the belt. Also herd alot of ppl say water pumps squeak just before they die, accompanied by some rattling/grinding sounds.. Good luck. Oh if it's a 5spd could be the release bearing. Use a stethoscope on the accessories while it's running too
That's unimpressive
Old 10-16-2011, 08:58 AM   #14
Ruthless's Avatar
My guess is water pump. My dads ford actually rusted the pump blades clean off once. When you run the car and it's warmed up. Turn your heater on. Pay attention to the temp of the air. If it starts really hot but then cools off and doesn't warm up then it's your pump. what is happening is you're not pumping enough water through the heater core and the air is cooling it faster than it can heat up. How many miles do you have?
Ruthless is offline   Reply With Quote
Old 10-16-2011, 09:14 AM   #15
PonyBoyV6's Avatar
Just hit 112k
Also, im going to try that turning on the heat thing, because every once in awhile it does sound like a slight grind going on.
Old 10-16-2011, 09:18 AM   #16
jhagan1980's Avatar
The guy locally that rebuilds starters and alternators said my rear bearing in my alt went bad and was squeaking. He rebuilt it and now that I can't hear it anymore I can now hear that my throw out bearing is bad. Fix one find another.
Old 10-16-2011, 09:24 AM   #17
Ruthless's Avatar
Also like he said bearings commonly go out. With the belt off try to wiggle all the pullys from side to side nothing should move at all.
Deep Sound 559Danny 1996-2004 Mustang GT 10 09-29-2011 07:09 PM
Nasty window sound austinknoll General Mustang Discussion 10 09-26-2011 10:11 AM
Annoying sound. NV Laser Red Pre-2005 V6 Mustang 29 09-20-2011 02:59 PM
This annoying "chirp" 100613mat 2005-2010 V6 Mustang 1 08-17-2011 08:07 PM
Sound of Borla exhaust mounted on (also some donuts and test ride video) martynas Pictures and Videos 1 08-07-2011 10:57 AM
04:03 AM
