Cam gears - Mustang Evolution
Old 10-16-2011, 07:00 PM   #1
2001mustang's Avatar
Cam gears
Can some one tell me wat cam gears do ??? Lol is it pointless ? Or is it good in any way an is that wat makes the car sound good on ideal ? Keep in mind it's a v 6
2001mustang is offline   Reply With Quote
Old 10-16-2011, 07:27 PM   #2
Brandanxstang21's Avatar
Cam gears are for aftermarket cams. And if you want the aggressive idle then exhaust and cams would be a good idea. (if you get cams you'll need cam gears because the factory cam gears are apart of the cam. And you might need valve springs for the higher lope of the cam)
Brandanxstang21 is offline   Reply With Quote
Old 10-16-2011, 07:32 PM   #3
Ok see now im just confused lol cam gears are the round things with spikes on it right ? An cam shaft is eat goes in the motor like in the heads ?
Old 10-16-2011, 07:34 PM   #4
Yeah, there are two timing chains that go from the crankshaft to the cam gears. Then the cam gears turn the cams. They're above the head( assuming you have a sohc).
Old 10-16-2011, 07:34 PM   #5
An would it give it any type of performe
Old 10-16-2011, 07:36 PM   #6
Cam gears alone wouldn't but cams would
Old 10-16-2011, 08:00 PM   #7
Yea it's a sohc so ur telling me the cam gears won't mak ur car ideal nice like a v8 ?
Old 10-16-2011, 08:04 PM   #8
Cam gears wouldn't. The camshafts would but if you got camshafts you'd need the cam gears. Or you could get headers and exhaust, that would make it sound good too.
Old 10-16-2011, 08:16 PM   #9
Dam it lol
Ok...3.55 vs 3.73 vs 4.10 Gears illestdomer2005 2011-2014 V6 Mustang 16 01-17-2015 09:17 PM
Gears guapoapo 2005-2010 Mustang GT 9 08-28-2011 11:29 AM
Gears Jesse Bach General Car Discussion 2 08-11-2011 06:19 AM
Cam gears t0t4lbl4ck0ut 1996-2004 Mustang GT 2 08-06-2011 12:47 PM
01:10 PM
