V6 K-members same as 4.6? - Mustang Evolution
Old 10-17-2011, 06:02 PM   #1
Otlaw80's Avatar
Do the 99-04 V6 cars have the same k-members as the 4.6 GT's? Looking at dropping a 4.6 from a police interceptor crown vic into a V6 car.
Old 10-18-2011, 08:56 AM   #2
kickerofdoom's Avatar
They are different. But a great upgrade why are you putting a 4.6 one?
Old 10-18-2011, 09:25 AM   #3
Otlaw80's Avatar
Not putting one in at this moment. Just for future reference. Will be looking for a project one in the future. I've got a friend of the family that has a complete set up from an old cop car. Engine trans computer and all wiring that he'll sell me for $400
Old 10-18-2011, 10:23 AM   #4
Ok nice yeah it going to be a lot of work
Old 10-19-2011, 10:11 AM   #5
Titus Wadicus
svtlx's Avatar
Re: V6 K-members same as 4.6?
i would advise trying to get sum 4.6 wiring harness for a stang. it will be more plug and play. just converted my 6 to an 8. wiring it up is super easy.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 10-19-2011, 11:22 PM   #6
93slowstang's Avatar
Didn't you put a pushrod in yours though?
Old 10-20-2011, 09:57 AM   #7
Titus Wadicus
svtlx's Avatar
yea, i did. so i didnt have to change my k-member..lol. but there are a few main harnesses in the passenger side kik panel that you have to tap into. if you use a stang harness it will blow your mind how plug and play it is. and u will be able to plug into the chassis harness under the hood as well.
lastly, match the pcm to the harness. if u use a 97 harness, use a pcm for a 97 to wutever years match. i cant stress this enough. the plugs all match up on the pcm's and harnesses, but the internal grounding and switching mechanisms is not.
i pop'd n a 93 pcm in my 95 harness.... and now i have a bent rod and partialy shattered piston.
anyway, im not sure on a crown vicky harness n your car. i just know from experience if you match the harness to the car that you will find that ford did a majority of the hardwork for you.
ive done a few efi v8 conversions from tbird, stangs, & f-150. so i have a lil bit of experience
Old 10-21-2011, 11:27 AM   #8
Otlaw80's Avatar
Thanx for the heads up and the info. Appreciate it.
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
Choosing a V6 over a V8 Shidifen 2005-2010 V6 Mustang 57 12-02-2011 05:19 AM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
10:25 AM
