Pain in the backside CAI question.... - Mustang Evolution
Old 10-09-2007, 10:08 PM   #1
Send a message via AIM to Siraco
I purchased, basically, this CAI. I have a 98 V6....... what the HELL? This thing came with no instructions and it doesnt look like it'll fit any which way... I am so confused
I did a Google search on "98 mustang cold air installation" and was glad that the picture of that CAI was the first thing to pop up considering thats exactly what i have.
This question was probably asked 540 times already, but I have searched the forums and even clicked on the CAI install links and it just brings me back to the main page. Could anyone help? I'd appreciate it alot! Thanks
Siraco is offline   Reply With Quote
Old 10-09-2007, 10:18 PM   #2
Re: Pain in the backside CAI question....
PM Kyle about his...have him get you a pic of it installed....it isn't nearly as tough as you would think...and once you see a pic you should be able to figure it out pretty quickly. Granted, his is a 2004, but, same engine and everything so it won't matter.
I'm going to see if I have a pic of his car with the hood up...but his motor is dirty, so he doesn't take many of the motor.
Old 10-09-2007, 10:21 PM   #3
Ok man, what you have there is your typical fenderwell cai kit. The pipe with the blue pieces on it connect to your throttle body and your MAF. The MAF must be pulled off of your factory air intake system, it's towards the front, right behind your current filter. You will need to pull out your factory air intake and unplug the harness.
Once you have this system out, unhook the air filter end and set it aside. If you look into the tube now you will see a screen and a small black plastic piece sticking into the tube. There are 4 bolts holding the MAF onto the factory intake, remove these 4 bolts and hold onto them.
Once you have seperated the MAF from the factory intake you can begin piecing together the new intake. First, connect the filter and the larger pipe together with that bracket piece inbetween. You will use one of the clamps on this. Now, bolt the MAF onto the pipe using the 4 bolts, you will want to reuse the metal screen in this process as well. Also, use the gasket supplied inbetween the MAF and the piping. Make sure you face this piece correctly so you can plug it back in (the plug side facing the filter side). Next, connect the upper piping to the rest of the system using another clamp.
Finally, after you have all this assembled, put it in the engine bay, carefully putting the filter side in the fenderwell first. Once you have this piece in, you can work on connecting the upper end of the piping to your throttle body, using another clamp on this piece.
Once you have all this connected you can hook the vacuum lines you unhooked back into this CAI and then plug the MAF connector back in. You will also want to attach the bracket piece onto the fender using the factory bolt.
Old 10-09-2007, 10:21 PM   #4
Awesome! I feel like a complete idiot not knowing how to do this, but hey at least i am trying haha..
Old 10-09-2007, 10:23 PM   #5
94-98 intakes are different, i think, than 99-04
but the way it looks in the pic is the way its installed. put that flat metal piece after the filter. that will be against the hole from your engine to fenderwell. that other metal piece with the two blue rubber things on it hook from that other metal tube to the throttle body, with that gasket in between both tubes.
the metal fasteners are for holding it all together.........its really not hard
Kyle is offline   Reply With Quote
Old 10-09-2007, 10:24 PM   #6
dammit brad, you beat me to it
i dont take ANY engine pics for that specific reason.......but i might give everything a nice cleaning this weekend as it is supposed to be nice and cool. finally fall is here........for at least a couple weeks now
Old 10-09-2007, 10:24 PM   #7
It goes from throttle body to fender wall...it is no different just different shaped pipes. It is the same as your kit.
Old 10-09-2007, 10:24 PM   #8
Where would the MAF go in your imaginary setup there Kyle?
Old 10-09-2007, 10:25 PM   #9
i guess, but if you look on the sales sites for these, they have two diff categories
Old 10-09-2007, 10:25 PM   #10
MAF? We don't need to stinking MAF. It is over rated...just like power steering.
Old 10-09-2007, 10:26 PM   #11
Right, but only because the pipes are shaped a touch different...the rest is all the same....and the install is identical.
Old 10-09-2007, 10:27 PM   #12
If you can't understand my instructions try these:
Google Image Result for http://lib.store.yahoo.net/lib/mustangtuning/CAI.jpg
Also, here's an image of a similar CAI setup...
Old 10-09-2007, 10:27 PM   #13
thats a good question.........mine had a plug for it
thats the one i got
Old 10-09-2007, 10:27 PM   #14
You just gotta put a power steering cooler on there.....
Old 10-09-2007, 10:28 PM   #15
important enough to install that power steering fluid cooler in my car
Old 10-09-2007, 10:28 PM   #16
thats the one i got
You have to bolt the factory MAF inbetween the two tubes, otherwise they would make it one big tube.
Look, there in the picture you posted, it's a MAF
Old 10-09-2007, 10:29 PM   #17
thats the one i got
Just so you know...the MAF is the piece that fits between that big L shaped piece and the smaller tube...it isn't really the plug...it is the entire assembly (MAF Housing). The rubber gasket clamps to one side of it and the L shaped pipe bolts to the other side.
Old 10-09-2007, 10:30 PM   #18
Exactly what I said in the novel posted above lol...we're arguing about the same thing apparently.
Old 10-09-2007, 10:30 PM   #19
I have the typical ford power steering pump whine and it sucks.
Old 10-09-2007, 10:31 PM   #20
That was completely off topic lol... yeah, my MAF is this big friggin round black thing, i do see the screen and stuff but... yeah its surrounded by black plastic lol.. I just take it out of that?
Old 10-09-2007, 10:31 PM   #21
No...I'm just typing slower than you and making the same points. lol
Old 10-09-2007, 10:31 PM   #22
Haha, well we're referring to me accidently hooking his tranny cooler up to the power steering lines...hence making a power steering cooler...didn't work as well as the theory sounds lol.
Old 10-09-2007, 10:31 PM   #23
Yes, I forget exactly how it all comes apart, one sec and I'll pull out my factory setup and take a look...
Old 10-09-2007, 10:32 PM   #24
Ah yes....good times....
You should have been here for the removal of the spun wheel stud. Now that was some real fun.
Old 10-09-2007, 10:35 PM   #25
Well mistake or not who else can actually say they have a power steering cooler? Haha
Old 10-09-2007, 10:35 PM   #26
Ok, back and sitting here with my factory MAF assembly in my hands...well lap..I'm typing.
The big honkin black plastic case ya know. It comes apart using a flat head screwdriver and prying at the 4 plastic clips holding it in. Once you have this unhooked you will see that the actual MAF is attached to the small portion of this assembly using 4 screws. Unbolt these 4 screws and work the wiring out of the housing and vuala *sp* you can start assembling your new unit.
*edit* now that I look at it a little harder there are 2 screws holding the MAF into the housing. You will use the new nuts and bolts sent with the kit to bolt this piece in the new setup. Be sure to use the gasket.
Old 10-09-2007, 10:43 PM   #27
Sweet! I can't believe how much of a help you guys are. Thanks so much!
Old 10-09-2007, 10:44 PM   #28
NP man, got nothing better to do with my time lol. Glad I could help, I remember when I first started getting into this, I had many of these threads floating around.
Old 10-10-2007, 05:41 PM   #29
success!
1998 Mustang, Blue, V6, Pony package... MTX 1000 watt 2 channel amp with the ****tiest sub, hopefully upgrading to two 12 inch JL audio subs very very verry soon..2.25 flowmaster muffler..would have a dual setup if i wasnt paying college off... CAI that i'm too dumb to put in myself... yeah i'm real proud of myself! :eek:
Old 10-11-2007, 09:29 AM   #30
Herbstang's Avatar
Nice !!!!! I was gonna chime in. But with Rob and Brad on the job you were in excellant hands !! Oh Yeah Kyle as well
Old 10-11-2007, 09:59 AM   #31
I don't know...the last time rob and brad were on the job, a tranny cooler suddenly became a power steering cooler.
Old 10-11-2007, 10:23 AM   #32
Herbstang's Avatar
That's OK it was only Kyle's car :rofl:
Old 10-11-2007, 10:25 AM   #33
That's true.
Old 10-12-2007, 10:32 PM   #34
I love the whistle i'm hearing when i drive, makes my car sound boosted, hah
cai
CAI question 96cobra 1996-2004 Mustang GT 6 03-19-2009 11:56 PM
CAI Question? KrazyPony 1996-2004 Mustang GT 12 07-18-2007 06:22 PM
CAI question Zuperzacker Pre-2005 V6 Mustang 2 06-22-2007 12:55 AM
CAI Question CakeOrDeath? Pre-2005 V6 Mustang 14 02-27-2005 09:23 AM
yet another CAI question The Arson Pre-2005 V6 Mustang 9 10-11-2004 08:19 PM
03:55 PM
