cannister purge solenoid - Mustang Evolution
Old 10-10-2007, 09:25 AM   #1
check engine light was on pulled code eecs purge solenoid malfunction. changed the solenoid cleared the code next day light back on with same code any suggestions.thanks
98mustang2007 is offline   Reply With Quote
Old 10-10-2007, 10:23 AM   #2
hottcobra's Avatar
Re: cannister purge solenoid
the solenoid is for your EVAP system witch pulles a vacumn on your fuel system. if you have a vacumn leak it can through this code. also check to make sure that intake vacumn is being applied to the solenoid
Old 10-10-2007, 11:04 AM   #3
Herbstang's Avatar
Are you getting any other codes like P0440 ???? check your gas cap a loose or bad cap will cause a large leak in the EVAP system..alot of people call this the "gas cap code"
What has happend is the PCM (computer) has seen a leak in the EVAP sytem and has turned on the light.
Here is how the PCM runs the test
The evaporative emission (EVAP) system is checked by applying vacuum to the EVAP system and by monitoring for a vacuum decay. The Powertrain Control Module (PCM) monitors the vacuum level through the fuel tank pressure sensor signal. At an appropriate time, the EVAP canister purge valve and the EVAP vent solenoid are turned ON, allowing the engine to draw a small vacuum on the entire evaporative emission system. After the desired vacuum level has been achieved, the EVAP canister purge valve will turn OFF, sealing the system. because the PCM is not detecting the expected vacuum. This can be caused by the following components with the conditions listed below:
The fuel cap for the following conditions:
Missing
Malfunctioning
Incorrect
The fuel tank pressure sensor for the following conditions:
Disconnected
Malfunctioning
The EVAP purge line for the following conditions:
Disconnected
Damaged
Pinched
Blocked
The EVAP vent hose for the following conditions:
Disconnected
Damaged
The fuel tank vapor line for the following conditions:
Disconnected
Damaged
Pinched
Blocked
The EVAP canister purge solenoid valve for the following conditions:
Disconnected
Malfunctioning
The EVAP vent solenoid for the following conditions:
Disconnected
Malfunctioning
An open ignition feed circuit to the following components:
EVAP vent valve
Purge solenoid
A damaged EVAP canister
A leaking fuel sender assembly O-ring
A leak in the following items:
Fuel tank
Fuel filler neck
Old 10-10-2007, 11:18 AM   #4
hottcobra's Avatar
^ ya what he said lol. I didn't think to go into that much detail but glad that you did. herb
Old 10-10-2007, 11:35 AM   #5
Herbstang's Avatar
copy and paste are my friends
My exhaust and N2O purge NorwegianMustang The Bar 21 01-30-2005 04:14 PM
Nitrous express system, purge, heater, bottle opener bigeyedfish Mustang Parts for Sale and Wanted 0 10-24-2004 06:04 PM
check out my purge video Zim The Bar 36 02-26-2004 05:03 PM
nitrous fuel solenoid installation Zim Pre-2005 V6 Mustang 8 11-13-2003 06:19 AM
06:02 PM
