Auto tranny - Mustang Evolution
Old 10-18-2011, 05:31 PM   #1
Auto tranny
I need to know how to read my automatic transmission dip stick in my 2003 V6 3.8L mustang ?? I pull it out and it has two sides with X's on them, one side sits higher and the other is at bottom. When I check this with engine at operating temp and engine running, it shows level to top of the bottom x's, the top x's do not show any fluid. Hope this makes sense..
Dogstang is offline   Reply With Quote
Old 10-18-2011, 08:50 PM   #2
kickerofdoom's Avatar
The top x is when your engine is running is when your supposed to check it.
Old 10-19-2011, 02:00 AM   #3
Re: Auto tranny
Thanks, that makes sense. I did check with engine running and nothing on the top X's, so I put some, small amount in and brought it up into the top X's, I will keep an eye on this. Thanks again.
Old 10-19-2011, 07:04 AM   #4
Yeah no problem remember if you notice it goes down you have a leak.
Old 10-19-2011, 07:56 PM   #5
Ghostedmind's Avatar
Normally the higher set of markings is so you can check it when its cold( its higher because theres more fluid in the pan because its not on yhe turning gears) and the bottom set of markings is for checking it at running temp
LCMC Member
Tranny/ clutch peoblem. Please help!! 96 stang 1996-2004 Mustang GT 26 09-27-2011 06:55 PM
dragging with auto? 5.slow At the Track 14 09-11-2011 10:20 AM
It's all coming together! New tranny and more.... drusmith SVT Mustang 18 07-21-2011 10:21 AM
Auto to Manual swap? BrKu789 1996-2004 Mustang GT 9 07-17-2011 09:17 PM
4.2 tranny 3.8boii Pre-2005 V6 Mustang 2 07-17-2011 02:45 PM
12:07 PM
