I dont know what this is... - Mustang Evolution
Old 10-23-2011, 06:02 PM   #1
My car has been doing this for a while... When I turn and I'm at a stop while I steer my rpms drop.. Like the car is about to die. It fluctuates rpms when I'm at a stand still and steer.
Blackedout is offline   Reply With Quote
Old 10-23-2011, 06:09 PM   #2
Blogger
99ford's Avatar
Re: I dont know what this is...
Usually they should go up just a little. Since it takes a little to power the pump. Hmm. This is interesting.
Old 10-23-2011, 06:18 PM   #3
It's just the drag on the engine from the PS pump.
Old 10-23-2011, 06:21 PM   #4
Is this bad?
Old 10-23-2011, 06:59 PM   #5
Blogger
99ford's Avatar
Is this bad?
No.In fact, Every car that I've ever driven with power steering does.
It just goes up and back down right? Not anything crazy.. Like go way up, or way down. It might jump it just a couple rpm then go back down.
Or if I was dishonest mechanic, I would say, yes.
Old 10-23-2011, 07:04 PM   #6
It goes down to like 500 rpms then back to normal rpms
Old 10-23-2011, 07:15 PM   #7
Blogger
99ford's Avatar
That is completely normal.
While were on this topic how long has been it since you had the Power Steering fluid flushed? Or flushed it? It is just one of those forgotten fluids.
Old 10-23-2011, 07:48 PM   #8
Year ago this month
Old 10-23-2011, 07:51 PM   #9
Blogger
99ford's Avatar
Cool! You should be good! You have nothing to worry about. I know that how that goes, if I wasn't on here I'd worry a lot more.
Old 10-23-2011, 10:03 PM   #10
Not at all...
Old 10-24-2011, 02:54 AM   #11
I may be over thinking things but I would double check your battery cable terminal connectors. Make sure everything has a clean connection from the cable copper strands to the terminal, to the battery posts.
Old 10-24-2011, 05:51 AM   #12
I recently got a new battery. And terminals from cables were a little corroded
Old 10-24-2011, 06:10 AM   #13
That does seem like a lot to drop. 500rpms. I would double check the PS fluid. If it gets worse then it could be going out.
Old 10-24-2011, 06:38 AM   #14
What's up fast?
Old 10-24-2011, 08:19 AM   #15
clean your MAF it can help as well as your IAC
Old 10-24-2011, 08:25 AM   #16
Thanks V will do
08:43 PM
