Cylinder 1 Misfire? - Mustang Evolution
Old 10-24-2011, 10:17 AM   #1
Cylinder 1 Misfire?
I recently bought a 1999 35th Anniversary V6 Mustang for my step-son for his 17th birthday. It's in great shape considering it has 183,000 miles on it. But it's starting to have a problem. It has a vibration and stuttering that I don't notice at highway speeds but it's very noticable when just cruising around town. I just put new plugs and wires in car when we bought it since they had never been changed, it still had the factory original in the car.... the problem seemed to get better but not completely fixed. After about a week of driving the stuttering came back along with the check engine light. I took it to the shop and it's showing a misfire on cylinder one. They pulled the plug and it was cracked. They replaced the plug free of charge and it again seemed to get better but still not completely gone. Now after about a week I'm back to having the same problem again.... Anybody have any ideas? What could be causing this over and over again? And why is the problem never completely going away?
stew99 is offline   Reply With Quote
Old 10-24-2011, 02:18 PM   #2
ForsakenProto's Avatar
Re: Cylinder 1 Misfire?
Try changing out the coil pack as well. As for the plug, if it keeps cracking, id suggest getting a different brand. Any idea what brand youre using currently?
ForsakenProto is offline   Reply With Quote
Old 10-24-2011, 09:42 PM   #3
Ghostedmind's Avatar
Ive been having the same issue....but its cylinder 3 on an 04, i was told our coil packs are paired cylinders, so instead of a misfire on only one cylinder it would be 2.....i also have replaced my plugs and wires....i was told it could be the cps, tps, maybe a valve or valve seal.....im supposed to be taking the valve covers off sometime in the near future to try to find the issue....but if you figure it out let me know what you did.if you dont mind and ill do the same
LCMC Member
Old 11-02-2011, 10:31 PM   #4
A couple of other possibilities would include a blocked or disabled injector. This can occur if a transistor blows on the computer or the injector fails. It can be checked with an injector test kit.
Second check the compression in the cylinder
OldTeddyBear is offline   Reply With Quote
Misfire 96 stang 1996-2004 Mustang GT 14 10-13-2011 10:23 PM
Misfire issues Ghostedmind Pre-2005 V6 Mustang 1 10-02-2011 12:52 AM
Cylinder heads 89white GT 1979-1995 Mustang GT 15 09-13-2011 10:12 AM
2011 Mustang 5.0 #8 Cylinder Problem LaFlamaBlanca 2011-2014 Mustang GT 35 08-29-2011 12:38 PM
Will a 6 cylinder C4 work with a 289 Tuch65 Classic Mustangs 2 08-11-2011 05:13 AM
07:19 AM
