hesitant acceleration - Mustang Evolution
Old 10-26-2011, 06:00 PM   #1
Chelley's Avatar
I have a 2000 v6 automatic and it starts fine, idles fine, no problems there. However, when I drive it the engine revs but the car doesn't accelerate. Then it "drops" into gear and finally accelerates. I've checked hoses, pcv, changed the transmission fluid and filter and put a new O2 sensor in. Any ideas what might be causing this?
Chelley is offline   Reply With Quote
Old 10-26-2011, 10:23 PM   #2
kickerofdoom's Avatar
How many miles
Old 10-27-2011, 04:56 AM   #3
Any cel?
Blackedout is offline   Reply With Quote
Old 10-27-2011, 05:44 AM   #4
Chelley's Avatar
219,000
Old 10-27-2011, 05:56 AM   #5
Any check engine lights?
Old 10-27-2011, 07:30 AM   #6
Jsan105's Avatar
Yea o had this problem but it when away after a tune up check if you have bad spark plugs wires Maf sensor
Jsan105 is offline   Reply With Quote
Old 10-27-2011, 10:23 AM   #7
Jsan105's Avatar
Ohhh I also changed my fuel filter
Old 11-03-2011, 11:28 AM   #8
I would def change the fuel filter then I would seafoam it.
Stubzmekenzie is offline   Reply With Quote
Old 11-03-2011, 06:32 PM   #9
shipwreck_98's Avatar
Re: hesitant acceleration
Its your transmission. Slipping clutches or sticking spool vlaves.
shipwreck_98 is offline   Reply With Quote
Old 11-05-2011, 02:21 AM   #10
Chelley's Avatar
Thanks guys but now it only goes in reverse. Do I need to get a new transmission? And yes the check engine light is on.
Old 11-08-2011, 11:22 AM   #11
Transmission rebuild is cheaper, if you know what your doing or have a good place to take it too. When you changed the fluid, it wasnt a complete flush, the new fluid broke loose some of the sludge in you tranny. You spool valves are probably stuck with varnish and all kinds of crap now. But you definitely need a diagnostic run on it, and yes it will throw codes and set your check engine light.
Old 11-08-2011, 12:06 PM   #12
Chelley's Avatar
Thanks
08:54 AM
