Rough at idle! - Mustang Evolution
Old 10-31-2011, 05:32 PM   #1
Ruthless's Avatar
Rough at idle!
So I went to start up the stang today and out if nowhere it was idling at about 500 rpm and was really rough any suggestions? Common problems? This was a one time occurrence and I'm assuming it's something stupid like bad gas. Anyone else have this problem?
Ruthless is offline   Reply With Quote
Old 11-06-2011, 07:48 AM   #2
Jmoss's Avatar
Re: Rough at idle!
I had this same problem go out and get some mass airflow sensor cleaner at the part store all you have to do it remove you mas from your intake unscrew it from the mount and give it a few squirts with the cleaner till you see it run clear just be careful not to touch the wire. Quick and easy fix now she runs like new
Jmoss is offline   Reply With Quote
Old 11-06-2011, 10:53 AM   #3
Ruthless's Avatar
Mass air flow sensor cleaner. Who would have thunk it?! And I assume that's an Autozone part? I will definitely be giving that a try. See and the weird thing is that it hasn't done it since. Maybe I can squeeze some extra gas mileage out of it too. Thanks for the info too bad I can't really post wether or not it fixes it since it's not a recurring problem... Thanks for the info maybe I'll post a how too with pics n junk. Yeah yeah!
Old 11-06-2011, 12:24 PM   #4
Jmoss's Avatar
O ya autozone or any auto parts store should have it quick fix takes no more than 10 mins start to finish
Old 11-06-2011, 02:18 PM   #5
Las0mbra's Avatar
Hey, and if this doesn't work ^ pm me and I can tell you what my car did. And I can how you a step by step and some pics if you need em. (could be IAC valve)
Old 11-06-2011, 03:28 PM   #6
Ruthless's Avatar
Iac was my other guess but again like I said it hasn't done it since. So I'm thinking it could be something as simple as bad gas maybe
Old 11-06-2011, 10:22 PM   #7
Las0mbra's Avatar
Eh, mine did that too... Maybe like once every 2 weeks.
Old 11-07-2011, 04:24 PM   #8
Re: Rough at idle!
Seafoam treatment!!!!!!! It will probably fix it but if it doesn't, it will at least help to eliminate most distracting second guessing.
Enter the Seafoam into any vacuum line or directly up the PCV valve. Put second full can into the gas tank.
Any questions; directions are on the can and YouTube has a thousand videos explaining how to do it. Trust me, it does wonders to our engines!!
idle problems brian94gt 1979-1995 Mustang GT 22 11-21-2011 08:44 PM
humming noise during idle robertoortiz85 1996-2004 Mustang GT 6 10-23-2011 02:12 AM
Stupid idle NateNasty 1979-1995 Mustang GT 23 10-17-2011 07:12 AM
Idle problems need some help stangrunner 1979-1995 Mustang GT 6 09-16-2011 07:49 PM
Running Rough. ColeJohnson 1996-2004 Mustang GT 25 09-12-2011 03:46 PM
10:38 AM
