Squeek - Mustang Evolution
Old 11-01-2011, 12:00 AM   #1
1qck6's Avatar
Squeek
I have a squeekin problem in my 98 v6 3.8l an it happends when you turn it on an then its stays squreking for a while longer then it graudualy goes away
1qck6 is offline   Reply With Quote
Old 11-04-2011, 09:24 AM   #2
shipwreck_98's Avatar
Re: Squeek
Where is the squeek coming from? Is it a manual?
shipwreck_98 is offline   Reply With Quote
Old 11-04-2011, 10:01 AM   #3
Re: Squeek
yea, is it from the engine, transmission etc,
Old 11-04-2011, 08:37 PM   #4
1qck6's Avatar
Its comeing somwere on the timeing band
Old 11-04-2011, 08:43 PM   #5
deadsp0t's Avatar
Probably just need a new serpentine belt.
That's unimpressive
Old 11-04-2011, 09:00 PM   #6
1qck6's Avatar
I did so idk
Old 11-04-2011, 09:11 PM   #7
deadsp0t's Avatar
I did so idk
So you did change the belt? Could be the release bearing for the clutch. If you can push or release the clutch and affect the noise that will help you realize that it is the problem
That's unimpressive
Old 11-05-2011, 07:42 PM   #8
1996v6stang's Avatar
Re: Squeek
this sounds a lot like the problem i have recently had. if it is it would be your crank angle sensor and camshaft position sensor. the crank angle sensor and camshaft position sensor are located under your coil pack assuming there arent any differences in our cars which i dont believe there would be. the sensor assembly goes in place of where there would be a distributor if it were an older car.
---------- Post added at 09:42 PM ---------- Previous post was at 09:40 PM ----------
if it were the tob or clutch the sound most likely wouldnt go away. atleast not from what ive experienced anyways.
1996v6stang is offline   Reply With Quote
Eibach lowered makes squeek IHBA 2011-2014 Mustang GT 3 08-04-2011 08:42 AM
Clutch Squeek?! pringle9666 Pre-2005 V6 Mustang 4 07-14-2011 04:24 PM
01:41 AM
