gears - Mustang Evolution
Old 11-02-2011, 01:45 PM   #1
waybad's Avatar
gears
Just seeing what kind of gears I should get for my 96 v6 its an auto, also what changes could I see performance wise? Thanks for reading!
waybad is offline   Reply With Quote
Old 11-02-2011, 10:08 PM   #2
Re: gears
4.10 gears and a bearing kit will make a huge difference in the driving experience every single time you drive the car. It never gets old, it's such a huge improvement accelerating from a dead stop or merging on the highway. You can still get Ford bearing kits 7.5" from stangmods.com.
Old 11-02-2011, 10:30 PM   #3
waybad's Avatar
How much do you think 4:10's and the bearings would run me $ wise?
Old 11-03-2011, 04:37 AM   #4
Re: gears
Exactly $499.95
Old 11-03-2011, 06:41 AM   #5
KATO's Avatar
Re: gears
Big thing is to research your area, on who can do the job and how much. I do have the 410 gears, I don't really know anything about the Bearing kit that was mentioned. You will notice a huge difference with it, be cautious with it when you first get it done, take time to get use to the difference in the gears, don't just hop in the car and slam on the gas (BIG NO,NO).
Old 11-03-2011, 06:36 PM   #6
waybad's Avatar
Do the auto v6's come with 3.73's?
Old 11-03-2011, 08:18 PM   #7
No think 272??? Something like that
Blackedout is offline   Reply With Quote
Old 11-04-2011, 01:47 AM   #8
Re: gears
Also remember I mentioned that stangmods.com is the only place I know of to get Ford gears (as apposed to Motive)- reputable Mustang shop is important.
Old 11-04-2011, 07:25 AM   #9
waybad's Avatar
Will the 4:10's kill my gas mileage on my v6 auto?
Old 11-04-2011, 07:40 AM   #10
KATO's Avatar
Re: gears
You may notice a little change in the mileage. I did notice a little change while on the HWY. It is said that: you will lose alittle on the HWY, but will gain a little in the city driving. I have noticed that.
Old 11-04-2011, 07:55 AM   #11
waybad's Avatar
Ok, I found em on AM.com for 165$. Thanks guys!
Old 11-05-2011, 03:32 AM   #12
Re: gears
I mentioned twice you can get Ford as apposed to Motive, but do as you like. The shop will probably ask for a bearing kit also.
Old 11-06-2011, 05:43 PM   #13
waybad's Avatar
Sorry, but is there any major diffrence in the ford and motive?
Old 11-07-2011, 04:11 PM   #14
Re: gears
My shop "recommended" that I get a set of Ford gears to, in their words: "help eliminats any gear whining or tolerance issues that may occur"- I myself would go out of my freakin mind if I hear any squeaks, noises, whining of anykind, anywhere, especially with how expensive they are and difficult to get installed.
Let it be known, I do not work on Mustang differentials every day for a living, so I only went with their advice and my gears are absolutely quiet.
You can Google the words- "Mustang Motive gear whining" and read up on it.
Also-stangmods.com sell both kinds, just gears, just rebuild bearing kits, or combo deals-FYI
Old 11-07-2011, 07:52 PM   #15
Wouldn't it matter all in who puts the gears in? Rather than it being a certain gear that whines?
---------- Post added at 09:52 PM ---------- Previous post was at 09:51 PM ----------
I'm asking this to make a point. Motive is a pretty good gear pack from what I heard. It's all about how you install them
Old 11-08-2011, 04:45 AM   #16
Just_John's Avatar
Region: South Dakota
Re: gears
I used to build gearboxes (not differentials) for a living. I have installed well over 500 sets of ring and pinion gears in Foote-Jones "Max Power" Spiral Bevel gearboxes, and I can tell you this with absolute certainty... different gear manufacturers use basically the same gear grinding equipment but use different tooling and techniques.
Some have a more pronounced spiral cut, while others are cut with more of a straight edge to the teeth. The way the gears are hobbed and ground is going to make a HUGE difference in the way they sound and how long they last. As soon as I opened a package and saw the gears, I could tell how they were going to sound under load.
The depth to the root of the gear teeth on the pinion and the corresponding depth of the teeth on the ring gear is also a consideration where noise is a concern. Some grind deeper than is necessary thus allowing for continual adjustment to correct backlash issues as the gears wear down.
This excessive root depth causes somewhat of a reverberation or cyclic hum. This is a great thing if you want long lasting gears that can be adjusted to compensate for wear, on the other hand though, this is a poor choice for a gear design if you want smooth and quiet.
Also, the amount of carbon in the steel and the degree to which the gears were heat treated will also have a great impact on the sound that is delivered from the gearset as it is rotating under load.
Simply stated: Not all gears are alike, and not all gears CAN BE ADJUSTED to run quietly.
As I stated above, my experience is in huge industrial gear boxes that are used to drive automotive assembly lines, coal mines, etc... not automotive differentials. However, the principles and manufacturing techniques are the same. Industrial and Automotive ring and pinion gears are made to the same standards and with basically the same equipment.
That being said... I would buy Ford gears, simply because I have never heard a stock mustang differential whine. People with 8 second cars don't care what their differential sounds like. People with daily drivers do.
Just my 2 cents.
01 V6 5 spd
Windstar upper, shorty headers, high-flow catted X, American Thunder catback, SCT Tuner, ASP 25% UDP, FRPP T-Lok
Just_John is offline   Reply With Quote
Old 11-08-2011, 04:58 AM   #17
KATO's Avatar
Re: gears
Good Info "Just_John". Thanks for adding that Info, it sounds about right.
Old 11-08-2011, 12:54 PM   #18
Re: gears
Just my 2 cents.
Yeah, Exactly. What I was wanting to say but don't have the knowledge. Thanks for the info, I will save it.
Ok...3.55 vs 3.73 vs 4.10 Gears illestdomer2005 2011-2014 V6 Mustang 16 01-17-2015 09:17 PM
3.73 Vs 4.10 Gears phobik 2011-2014 Mustang GT 30 04-08-2014 01:07 PM
Gears.?.? Mach General Car Discussion 1 08-26-2011 12:02 AM
Gears Jesse Bach General Car Discussion 2 08-11-2011 06:19 AM
Any idea of what rear end gears i may have in my 92 GT? macmarine39 1979-1995 Mustang GT 4 07-16-2011 08:25 PM
10:59 PM
