Bad Fuel Filter? - Mustang Evolution
Old 11-05-2011, 08:45 AM   #1
Region: New Mexico
Bad Fuel Filter?
OK, let's try this again. 2004, 3.8 V-6 stalled out at a traffic light. Tries to start, but won't quite make it. Other symptoms: Used 1/2 tank of gas in 2 days - at least twice what it normal did. Kind of hard to start a couple days ago, but OK since. What would it be? I'm thinking bad fuel filter, but that wouldn't explain the large amount of gas used in just 2 days. What do ya say, folks? Any ideas?
chrissiesstang is offline   Reply With Quote
Old 11-05-2011, 08:50 AM   #2
PonyBoyV6's Avatar
Bad fuel injectors, bad plugs wires, hole in fuel line (would be really obvious but just suggesting) im no mechanic, but i've had problems with bad plugs and wires, and it gave me absolute crap for gasmileage. And, car hated to start up. But it never died out on me like that, sorry i cant be of more help but goodluck!
PonyBoyV6 is offline   Reply With Quote
Old 11-05-2011, 09:05 AM   #3
kickerofdoom's Avatar
Any lights on,all fluid normal
Old 11-08-2011, 11:40 AM   #4
shipwreck_98's Avatar
Re: Bad Fuel Filter?
Could be the fuel pump, or a fuse. It might even be the relay under the passenger side fender by the air scoop.
Could also have a vacuum leak.
shipwreck_98 is offline   Reply With Quote
Old 11-09-2011, 04:51 AM   #5
If you replace the fuel filter and see "rusty" fuel come out, run it for a day and replace it again with 2nd new one till clear fuel appears. If engine temp is getting up to normal temp with no codes, then get some plugs, clean the air filter, and do 2 cans of Seafoam treatment. The tri-colored vacuum lines to EGR are brittle and break easily.
When your done with the PM work, reset the computer.
1995 3.8 Mustang Knocking Sound <Transmission> Fuel Injector<AOD????? HELP> Jsan105 Pre-2005 V6 Mustang 2 10-26-2011 07:24 PM
Bad Fuel Pump?? jal4411 1979-1995 Mustang GT 7 09-17-2011 02:32 PM
fuel problem fordgirl1209 Pre-2005 V6 Mustang 10 08-25-2011 06:18 PM
Fuel Filter replacement problem 99 SVT Cobra SVT Mustang 13 07-31-2011 07:25 AM
Fuel filter 04TRV6 1979-1995 Mustang GT 13 07-08-2011 03:21 PM
02:34 PM
