Headlight humid - Mustang Evolution
Old 11-08-2011, 03:56 PM   #1
Headlight humid
Theres moisture in my halo lights and they are extremely foggy, I sanded them down to buff them ot but the fog within them from the moisture prevents me from seeing anything ary night, should I just replace the lights
Niko Cherad is offline   Reply With Quote
Old 11-08-2011, 09:24 PM   #2
V6Mustang40th's Avatar
Region: Utah
Headlight Restoration Kit...
Before
After
Worked okay
V6Mustang40th is offline   Reply With Quote
Old 11-08-2011, 09:25 PM   #3
Region: Utah
AFTER After...
Old 11-09-2011, 10:05 AM   #4
I have the same issue
Old 11-13-2011, 08:04 AM   #5
Re: Headlight humid
A higher quality headlight fluid would do the trick. I can sell you some cheap-
Old 11-13-2011, 07:56 PM   #6
ramosjose16's Avatar
Is it because of normal use, or like from cold days.?
ramosjose16 is offline   Reply With Quote
Old 11-13-2011, 07:58 PM   #7
shaqfu's Avatar
Re: Headlight humid
did you crash into something?
shaqfu is offline   Reply With Quote
Old 11-13-2011, 08:11 PM   #8
Region: Utah
T-boned a guy
Old 11-14-2011, 02:07 AM   #9
Re: Headlight humid
I had a halogen explode inside one of mine. Because it stained the inside I have no choice but to get new ones. I seal all the way around behind the weather strip before installing new ones but if moister gets inside and doesn't dry clearly, you have to heat them up to disassemble or replace them. But even the best manufacturers can fog up if you don't use sealant around the entire two seams before installing first time.
I am having a hard as hell time of choosing a style. I hope your Halos dry up nicely so you can seal them up and not worry about it again. Good Luck!
Need Advice. Mustang Headlight Fogged Up. AllanBane 1996-2004 Mustang GT 3 10-17-2011 06:37 PM
headlight restoration best product? dbroncolish 1996-2004 Mustang GT 8 09-19-2011 04:09 PM
Left low beam headlight wont work but i will when i turn on high beams p1blake04 1996-2004 Mustang GT 4 09-05-2011 10:30 PM
Mothers all in one headlight restoring kit znpzmustang Mustang Paint, Appearance & Detailing 9 08-09-2011 06:11 PM
Headlight Aaron vassallo 1996-2004 Mustang GT 2 07-01-2011 07:10 AM
12:09 AM
