Rod bearing - Mustang Evolution
Old 11-09-2011, 11:18 AM   #1
Rod bearing
I think I hear a rod bearing does that mean the previous owner did not maintain the pony properly
Niko Cherad is offline   Reply With Quote
Old 11-10-2011, 03:33 AM   #2
Re: Rod bearing
Before any panic, I would do some preventive maintenance. Unless it's an ungodly knock which I would think would be throwing codes before it dies.
Seafoam the upper intake manifold. Put one can in gas tank too. Plugs, fuel filter, correct weight oil and filter.
Old 11-21-2011, 11:30 AM   #3
Thanks
Old 11-21-2011, 11:36 AM   #4
stampde's Avatar
Re: Rod bearing
if tits a rod bearing there's no saving it ,it'll get worse ....
2011 GT Auto
Old 11-21-2011, 01:53 PM   #5
Re: Rod bearing
depending on the severity and condition of the journals, you could drop the oil pan and change the bearings. some people get lucky like that.
1968 mustang coupe 357W: SpeedPro lower, XE282, Trickflow 185cc, Weiand, 650 Holley, gasket portmatch, Hooker Headers, Full MSD, C6, Built 9"
2001 V6: KYB adjustables, H&R springs, Cosmetics, CAI, X-Pipe, Full Exhaust, T5
PR6R is offline   Reply With Quote
Old 11-22-2011, 08:50 AM   #6
Re: Rod bearing
Wow, thats a scary thought, amount of neglect or circumstances to get to that condition.
I personally would do what I always do anyhow- Seafoaming the upper intake manifold is a huge preventive maintenance need. It eliminates knock, O2 codes, lean mixture codes, and mpg rise Big Time-
-Seafoam full can in gas tank, full can pulled into vacuum line.
-fuel filter replaced until fuel is clear colored
-copper plugs for best diagnosis performance
-clean air filter/MAF sensor
-pcv valve
-EGR hose connections tight (all three of them)
-I have been using (300K miles) Mobil1 Extended Service Oil. I use Amsoil Ea Oil Filters, Royal Purple, K&N, Mobil1, all make great filtrating filters.
Do yourself a huge favor and suck a can of Seafoam slowly into intake right through pcv valve with a drinking straw- Easiest way- Good Luck!
New Hot rod mag XXSTEVEO66 Pictures and Videos 3 10-15-2011 08:47 PM
Hot rod...F-250? Otlaw80 General Car Discussion 0 08-25-2011 10:16 PM
Throw Out Bearing? USAF_stang 1996-2004 Mustang GT 9 07-20-2011 02:07 PM
rod streangth teksidtwovalve SVT Mustang 0 07-09-2011 12:41 AM
Panhard Bar and Rod Support Suggestions poloka 2011-2014 Mustang GT 22 07-02-2011 08:56 PM
04:43 AM
