make your own RAM AIR kit - Mustang Evolution
Old 11-03-2003, 09:23 AM   #1
here are two different howto's:
http://www.corral.net/tech/powerplant/ram-cold-air.html
http://www.geocities.com/v6sprout/ramairhowto.html
geanders is offline   Reply With Quote
Old 11-03-2003, 09:52 AM   #2
Zim
You want to **** me?
Zim's Avatar
that second one looks like it sucks... lol
I like toys
Old 11-03-2003, 10:09 AM   #3
it looks kinda ghetto to me too, but I was liking the dual ram air concept, was thinking of mergin the to together, and using the aluminum but to make a dual ram air induction w/also using my "vornado" fuel savers to spin the air inside the pipes? Also the aluminum would allow me to mold the air ducts around my stock v6 fog lights(oval shape).
Old 11-03-2003, 01:13 PM   #4
you use the tornado?
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 11-03-2003, 01:23 PM   #5
Danger Dude's Avatar
Dude spinning air will do nothing for you in the intake tube as soon as the air hits the crossover tube on its way to the plenum the swirl will be gone
Take the vornado and send it to Kansas they like swirly things out there. HAHAHAHAHHAHAAHHAHAHHAH J/K sort of
Old 11-03-2003, 01:29 PM   #6
whats with the ram-air fascination all of a sudden?
they arent worth it.
New Hottness
1999 V6 5-speed
Wrecked
Old 11-03-2003, 04:18 PM   #7
Monkey's Avatar
this is a bolt-on and moving it there
Old 11-03-2003, 04:21 PM   #8
Zim
Zim's Avatar
lol... yeah we do actually. I took this from my dorm window last year
I like toys
Old 11-04-2003, 09:51 AM   #9
that first ram-air won't even work as a ram-air. look at all the tubing it has to go through.
2000 5spd black/ cai w/ k&n, dual exhuast w/ H-pipe
stangracer is offline   Reply With Quote
Old 11-05-2003, 06:50 AM   #10
Ken
Ken's Avatar
Region: New Hampshire
What happens with rain, water, puddles etc with a ram-air setup?
Won't it soak the filter and REDUCE performance? and possibly damage the engine??
Ken is offline   Reply With Quote
Old 11-05-2003, 06:53 AM   #11
No if you have a CAI that goes into the fender area and points down at the opening of the fender and engine bay you dont have to worry do you . unless you drive your stang across rivers or flooded areas like you would in the rubicon it is not a bother what limited water might get on the filter
Old 11-05-2003, 07:01 AM   #12
Ken
Ken's Avatar
Right, but with those links showing the home-made 'ram air' setup..
The front of the car gets soaked in the rain while driving, won't it just allow that moisture a direct path to the filter? The cai won't really get direct water on the filter like those ram-air setups will.
Are you saying that the amount of moisture is really not as much as it may seem? Or are these guys taking a HUGE risk for minor gains?
Old 11-05-2003, 07:04 AM   #13
no risk and minimal amout of moisture
Old 11-05-2003, 08:27 AM   #14
no gains and minimal amout of moisture
New Hottness
1999 V6 5-speed
Wrecked
Old 11-05-2003, 01:45 PM   #15
RGR
Send a message via AIM to RGR
Sorry U nay-sayers, but I built a home made Ram-Air about 4 years
ago that really helped my 89 GT! Helped from a dead stop too!
But I had only a K&N in the stock airbox before, and added the
Ram-Air to that. Never had a problem with moisture, the rain drops are
heavy enough to just hit the sides of the tubing and basically stop.
What little makes it to the filter box would drip down into the bottom
and I believe there are a couple of weep holes in the bottom that it would run out.
Other than that it is OK to get moist air into the engine, ever hear of
water injection? That puts in more water than you would ever get in a
huge rainstorm that you would be driving in. My stangs have all been
"squirrely" in wet weather sorry for the reference Ken
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Custom Ram Air SVTCOBRA Mustang Audio & Video 4 04-28-2009 03:19 PM
3.8 95 Ram Air Shaker? v6Stangin95 Pre-2005 V6 Mustang 4 09-14-2005 01:21 PM
Ram Air Induction Dragon_Lady 1996-2004 Mustang GT 6 07-31-2004 10:34 PM
ram air Black00GT 1996-2004 Mustang GT 8 03-23-2004 12:03 PM
RAM air kit jwscorpio Pre-2005 V6 Mustang 6 02-20-2004 12:26 PM
11:49 AM
