Trunk clunk from bumps - Mustang Evolution
Old 11-19-2011, 11:18 AM   #1
Have an 02' V6 manual transmission with a weird clunking noise coming from the trunk any time I hit a bump. I've checked suspension, the trunk latch, and for lose item in the trunk, all to no avail. I also cannot reproduce the noise while not moving. The trunk it tight and the latch it solid, yet the noise still seems to be coming strait from the latch assembly. I even tied the glow in the dark trunk release to the top of the trunk to see if that was it.
If anyone has some insight into this I would appreciate it.
Macluva18 is offline   Reply With Quote
Old 11-19-2011, 02:21 PM   #2
Rascal's Avatar
Re: Trunk clunk from bumps
i had this problem last summer after i rotated my tires ended up being my spare tire and jack. i didnt have the jack in the spare tire right and it was rattling around over bumps and what not. its gotta be wound up just right to fit snug in the spare tire
Rascal is offline   Reply With Quote
Old 11-19-2011, 02:24 PM   #3
Thanks! But would you believe me if I said I don't have a spare or jack back there? It's true. Is there a part that is underneath where that spare would normally be that would hang lose?
Old 11-19-2011, 04:28 PM   #4
Horseplay's Avatar
I got the same problem with my 01 v6. And I don't got a jack or spare in the trunk either. I think my gas tank has to do with it because it doesn't seem to close right. But idk if it could be something else.
Low2v
Old 11-19-2011, 04:48 PM   #5
jhagan1980's Avatar
I know my front end did this and it turned out to be the struts.
jhagan1980 is offline   Reply With Quote
Old 11-19-2011, 05:12 PM   #6
Horseplay's Avatar
I replaced my struts and shocks and it did help a lot. But I still little shakes in the back area. I wonder if I get a new gas tank door it will go away.
Low2v
Old 11-19-2011, 05:22 PM   #7
Hmm. I have a shorter friend. I think I'm going to pull down the back seats and stick him in the trunk to try and pin point exactly where the noise is coming from.
Old 11-19-2011, 05:47 PM   #8
Horseplay's Avatar
Lol wth that would be hilarious
Low2v
Old 11-20-2011, 08:15 AM   #9
shipwreck_98's Avatar
Check the exhaust, the bend in the pipe over the axle might be hitting the body, or the axle.
shipwreck_98 is offline   Reply With Quote
Old 11-20-2011, 08:25 AM   #10
Horseplay's Avatar
Wow I've never thought of that . I'll Chek it out thanks!
Low2v
Old 11-20-2011, 10:11 AM   #11
Check the rubber muffler mount while you are down there, might be worn and stretched. That would cause the tail pipe to jump.
Loud Clunk V6Mustang40th Pre-2005 V6 Mustang 6 11-12-2011 12:00 PM
trunk light help RVAStang05 2005-2010 Mustang GT 1 11-03-2011 01:00 PM
Trunk is dark OmegaRedGT 2007 2005-2010 Mustang GT 16 11-01-2011 07:48 PM
Trunk release on 07 GT uh60facilitator General Mustang Discussion 5 08-17-2011 11:56 AM
Trunk bulb MVP u eNVy ME 2005-2010 Mustang GT 2 08-09-2011 07:37 AM
06:50 AM
