Evaporative Emissions Valve - Mustang Evolution
Old 11-22-2011, 10:23 PM   #1
Evolution's Avatar
A few days ago i was in the parking lot with a couple buddies and he reved his car, so i did mine, and 1 hour later my check engine light came on. I got a code reader and it was a code for, Evaporative Emission control system valve. So realisticly i over reved my car. Any solutions to solve this problem, any type of help would be appriciated.
(i won the rev competition :] )
Evolution is offline   Reply With Quote
Old 11-23-2011, 07:09 AM   #2
shipwreck_98's Avatar
Re: Evaporative Emissions Valve
1. Using a scan tool, command the purge solenoid to activate. Listen or feel for a clicking coming from the purge solenoid. It should click once, or on some models it may click repeatedly.
2. If it doesn't click with scan tool activation, unplug the connector and examing the solenoid and connector for damage, water, etc. Then check for battery voltage on the feed wire with the key on. If you have battery voltage, then ground the control side manually using a jumper wire and see if the valve clicks. If it does, then you know the solenoid is working properly but there is a problem with the control circuit. If it doesn't click when you manually ground it, replace the purge solenoid.
3. To check for a problem on the control circuit (if the solenoid tests okay and you have voltage to the solenoid) plug the solenoid back in and remove the control circuit (ground) wire from the ECM connector (If you're unsure how to do this, do not attempt). With the ground wire removed from the ECM, turn the key on and then manually ground the Purge valve control wire. The solenoid should click. If it does, then you know there is no problem with the control wire to the solenoid and there is a problem with the ECM purge solenoid driver circuit in the ECM. You'll need a new ECM. However if it doesn't click, then there must be an open in the wiring between the ECM and and the solenoid. You must find it and repair it.
shipwreck_98 is offline   Reply With Quote
Old 11-23-2011, 07:11 AM   #3
Petty_stang's Avatar
I'd get a tuner if you don't have one. Then you can set exact rev limits and make sure this doesn't happen agin
Petty_stang is offline   Reply With Quote
Pcv valve Jpstang 1979-1995 Mustang GT 5 11-26-2011 09:55 AM
valve covers Berbantor 1996-2004 Mustang GT 0 11-15-2011 01:29 PM
Underdash components & Emissions System mcdonaldnick 1979-1995 Mustang GT 1 10-13-2011 11:45 AM
PCV Valve MustangGT02 1996-2004 Mustang GT 1 08-27-2011 08:46 AM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 05:29 AM
07:36 PM
