Help? - Mustang Evolution
Old 11-28-2011, 09:28 AM   #1
Petty_stang's Avatar
Help?
Went to crank my car this morning to go to class and it sounded like the battery was dead, no big deal but the tach and speedometer turned all the way to the right and hav stayed there. Tested battery and it's got a full charge, any ideas on what's wrong?
Petty_stang is offline   Reply With Quote
Old 11-28-2011, 04:36 PM   #2
mustangg2000's Avatar
Region: Arkansas
Check all connections need them tight ... mine did that a few times and it was because the negative cable was loose..
mustangg2000 is offline   Reply With Quote
Old 11-28-2011, 05:27 PM   #3
Ok I hope it's something small like that
Old 11-28-2011, 08:53 PM   #4
bryanbrock's Avatar
Re: Help?
may be voltage regulator, may be alternator, disconnect clean and reconnect terminals, take car to advance, and have them run a free code reading and test the alternator charge while there at it.
bryanbrock is offline   Reply With Quote
Old 11-29-2011, 08:56 AM   #5
Re: Help?
YES in deed! Check the bare stranded copper cable, the terminal, and the battery post. Negative side most likely but check both!
Old 11-29-2011, 05:18 PM   #6
Checked everything out and it's still doing the same thing. It's not throwing any codes either.
Old 11-29-2011, 06:38 PM   #7
Blogger
99ford's Avatar
Re: Help?
If all connections are good, just go get a new battery. My brothers car had the same issue it would crank, crank, crank, crank, dddddddddddd crank whom!! Then some stupid **** started happening, took it to get tested full charge several times, he coughed it up bought a new battery. Almost talked him to buying a new SHO.
Old 11-30-2011, 05:39 AM   #8
Re: Help?
I had some similar stupid *** problems constantly for a while. Went ahaed and installed a Red Optima battery. That's one great battery.
Old 11-30-2011, 07:24 AM   #9
I just picked up one. This fixes it I hope
Old 11-30-2011, 07:44 AM   #10
Region: Arkansas
Re: Help?
I agree one badass battery I have one as well
Old 11-30-2011, 12:42 PM   #11
Just put mine in and it cranked right up!
Old 12-01-2011, 06:52 AM   #12
Re: Help?
Yessss!
Old 12-01-2011, 07:03 PM   #13
But now at idle the rpms arents as stable and wen they dip down the car shakes??? Any ideas on what going on?
Old 12-02-2011, 12:23 PM   #14
Re: Help?
You reset the computer by replacing the battery but I would check for a simple vacuum leak around the egr valve or CAI if you have one. The egr has 3 plastic lines color coded, they get very brittle with time, not flexible.
Old 12-02-2011, 03:02 PM   #15
Where are they located?
Old 12-04-2011, 07:05 AM   #16
Re: Help?
All the vacuum lines start out together drivers side firewall, the egr is next to/behind the throttle body. I believe it has one line on top, three underneath, and one of those go directly into upper intake manifold. They are bundled up together until they get to egr, hope thats helpful somehow-
Old 12-04-2011, 06:15 PM   #17
That helps a lot actually. All I did was touch one and it disintegrated lol
Old 12-05-2011, 08:10 AM   #18
Re: Help?
The crack before it disintegrated can cause problems. I re-ran all those lines with new tubing a long time ago.
Old 12-05-2011, 09:49 AM   #19
Ya sounds like I need to get on that
07:47 PM
