oxygen sensor - Mustang Evolution
Old 12-01-2011, 11:53 AM   #1
kickerofdoom's Avatar
oxygen sensor
I just got a code for lean on bank two which is normally oxygen sensor. I have 155,000 miles so its not uncommon but how hard are they to change and which side is bank 2
Old 12-01-2011, 01:15 PM   #2
Re: oxygen sensor
Just because its lean doesn't mean that its bad, fwiw.
I have never changed the 02's on my mustang, but I have on my camaro and its not that big of a deal.
Find where they plug in.
Unscrew them.
Unplug them from the harness.
Plug new ones in and screw them back in.
EDIT: Just read the part about bank2. It should be on the passenger side.
UMSaleen is offline   Reply With Quote
Old 12-01-2011, 08:40 PM   #3
davidcseifert's Avatar
Region: Arkansas
Re: oxygen sensor
-_- bank 2 is the drivers side, remember bank 1 goes on the same side as cylinder 1 which on the V6 is the passenger side
drivers side = bank 2
passenger side = bank 1
so its just saying one side? what about the front to back signal for the O2? it should say bank two bank ____ it shouldn't just say it's one side of the car, what is the code?
Old 12-02-2011, 09:06 AM   #4
shipwreck_98's Avatar
Re: oxygen sensor
Its highly unlikely the O2 sensor is bad because you are reading a lean condition on bank 2. You should check why its reading lean, it is more than likely a problem in one or more of your cylinders on the drivers side. Could be a misfire or a minor vacuum leak. You should find the source of the issue first, if you replace the sensor and not fix the source problem it will just return.
shipwreck_98 is offline   Reply With Quote
Old 12-05-2011, 12:39 PM   #5
You could always swap sensors and see if the code follows (changes to bank1), if it does replace the sensor, if not then like the above post said you might have a vacuum leak.I think it could also be a dirty injector or exhaust leak.
Stubzmekenzie is offline   Reply With Quote
Old 12-06-2011, 07:09 AM   #6
With my 1995 v6, a scanner read almost the same problem but both banks. Revolutions did not exceed 2000. Fixed it by carefully washing sensors with 95% alcohol (using wife's aquarel brush).
breguet is offline   Reply With Quote
Speed sensor Butch SVT Mustang 1 12-01-2011 01:22 PM
does cluster gauge affect sensor?? jmpark527 2005-2010 Mustang GT 0 11-23-2011 08:32 AM
Low Tire Sensor on Benjammin1829 2011-2014 Mustang GT 12 11-01-2011 12:46 AM
Does foxbodys have a knock sensor? Stang.racr 1979-1995 Mustang GT 8 07-20-2011 03:28 PM
MAF sensor Mustanglife Pre-2005 V6 Mustang 5 07-01-2011 07:22 AM
06:34 PM
