Tires & Gas Mileage - Mustang Evolution
Old 12-01-2011, 12:09 PM   #1
98mustang11's Avatar
Tires & Gas Mileage
How much difference do tires make when it comes to gas mileage
98mustang11 is offline   Reply With Quote
Old 12-01-2011, 01:33 PM   #2
Just_John's Avatar
Region: South Dakota
Re: Tires & Gas Mileage
I was told by the guys at the local Goodyear store that these "low rolling resistance" tires designed to increase fuel economy are a hoax... in their words. They said that throughout the life of the tire you may save about ONE tank of gas, which isn't enough savings to justify the additional expense of the tires in the first place.
They said "Buy cheap tires and keep them properly inflated - don't buy into the hype".
Others may have different opinions...
01 V6 5 spd
Windstar upper, shorty headers, high-flow catted X, American Thunder catback, SCT Tuner, ASP 25% UDP, FRPP T-Lok
Just_John is offline   Reply With Quote
Old 12-01-2011, 01:59 PM   #3
Well I'm getting really bad gas mileage it didn't start till I put a different size on had 225 55r on now its 225 65s. The ones that where on it where z rated and really expensive
Old 12-01-2011, 02:19 PM   #4
Las0mbra's Avatar
Honestly, performance cars don't have the tire gas mileage issue. My dad has a jeep wrangler and mud tires make the gas mileage awful (same diameter).
Old 12-01-2011, 02:27 PM   #5
Well I really need to fix the gas problem cause I drive 80 miles a day to work I was getting like 400 miles a full tank .... its straight highway to work ... any suggestions
Old 12-01-2011, 03:07 PM   #6
Las0mbra's Avatar
Have you tried seafoam?
Old 12-01-2011, 06:35 PM   #7
YeP can in gas tank and intake
Old 12-01-2011, 08:26 PM   #8
davidcseifert's Avatar
Region: Arkansas
you added taller tires (by a lot) 225/55 tires compared to 225/65 tires make a big difference, from the original tire size i'm guessing you have 16" rims??
so a 225/55-16 tire is 25.7" tall and a 225/65-16 tire is 27.5" tall that's an extra 1.8" height of tire that your V6 has to turn over......
only option is swap back to the proper size tire......... not to mention your speedo is way off
Old 12-01-2011, 10:48 PM   #9
Yea well the ones I had wear going flat so I got a set for 50 bucks couldn't really complain
Old 12-02-2011, 03:05 AM   #10
DaBluedude's Avatar
Get the proper ratio tire... that's about it. Low rolling resistance tires are a scam and they hurt performance. They can also be damaged by high speed and there braking performance is disgusting. How they allow them on the road is puzzling.
You could install a lower gear... but 400 miles a tank isn't bad.
2003 Mach 1
Old 12-02-2011, 11:35 AM   #11
Yea was getting 400 now its 200 I don't know what the deal is .. I'm gonna clean the throttle body iac and maf
Old 12-02-2011, 11:52 AM   #12
Region: Arkansas
I get about 250 if I'm lucky
OP: not to sound like an *** here but, if the tires are all that changed then your mileage went to crap.... THE TIRES ARE THE PROBLEM no amount of cleaning you can do to anything will change that lol
blower/new cam soon
Old 12-02-2011, 11:54 AM   #13
That's what I'm thinking just rather do little cheap things first before shelling out money on tires
Best bang fit your Buck GAS MILEAGE mod 86 muscle 1996-2004 Mustang GT 19 12-18-2011 09:21 PM
1999 Cobra replacment Tires jgarey SVT Mustang 4 11-07-2011 11:01 AM
gas milage osonasty General Mustang Discussion 15 10-22-2011 12:11 AM
gas stations riping you off! robertoortiz85 General Car Discussion 2 10-20-2011 12:50 PM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 10:55 PM
06:22 PM
