Windshield washer/sprayer - Mustang Evolution
Old 12-01-2011, 12:19 PM   #1
NYmustang5's Avatar
My windshield washers dont work. has anyone fixed this before, any input would be greatly appreciated
NYmustang5 is offline   Reply With Quote
Old 12-03-2011, 11:10 PM   #2
NYmustang5's Avatar
Anybody come on guys dont be shy! Help a nikka out
Old 12-04-2011, 04:03 AM   #3
kickerofdoom's Avatar
Well first you have to open where the fluid spray from and check the hoses to see if they are okay,if fine then get like a needle and clear the spray thing of dirt
Old 12-04-2011, 06:44 AM   #4
96civic87's Avatar
You can easily take the cowl panel of simply by pullong straight up on it. Theres no bolts involed just snap clips then you can look/inspect a little easier.
96civic87 is offline   Reply With Quote
Old 12-04-2011, 08:49 AM   #5
NYmustang5's Avatar
Thanx man, i thought it was more complicated than that
Old 12-06-2011, 07:34 PM   #6
Re: Windshield washer/sprayer
The motor/pump is at base of wwasher reservoir. have someone hit spray while you're at it. you should hear it run. if not, see if it's getting 12 volts by unplugging and check with light tester. if it hums unplug hose and see if fluid sprays out. if it does find clog.
earthdeth is offline   Reply With Quote
Old 12-06-2011, 10:02 PM   #7
etc1006's Avatar
Or even the hose got brittle/rotten with age and broke off, usually in the cowl.
etc1006 is offline   Reply With Quote
Fixed my windshield washers! RVAStang05 General Mustang Discussion 7 11-25-2011 06:24 AM
Windshield wipers SlimSexy Mustang Paint, Appearance & Detailing 0 10-27-2011 01:40 PM
Replace windshield squiter nozzle? RHINOE_05GT Mustang Paint, Appearance & Detailing 0 10-03-2011 09:32 AM
10:45 AM
