Hard starting in the cold - Mustang Evolution
Old 12-02-2011, 05:59 PM   #1
Ilovemustangs88's Avatar
My 2000 mustang starts hard in the cold. I usually have to try two or three times to start it then once it starts it's good. I just bought a new battery the biggest that will fit. I was just wondering if anyone else has this problem or knows what I can do. It always starts but its harder when it gets below freezing
Ilovemustangs88 is offline   Reply With Quote
Old 12-02-2011, 08:28 PM   #2
When you say starts hard you mean like crank and the car feels like it vibrates real hard?
Blackedout is offline   Reply With Quote
Old 12-02-2011, 11:12 PM   #3
davidcseifert's Avatar
Region: Arkansas
Re: Hard starting in the cold
she's saying it's hard to start when it's cold from her description.....
unless you have a drain on your battery it shouldn't be hard to start from an overnight sit, question, if you start it up drive around a little and shut it off does it have trouble restarting like when it's cold?
blower/new cam soon
Old 12-03-2011, 07:09 AM   #4
No it's usually just in the morning after sitting all night. When it was warmer it started right up but now that it's below freezing out its having some trouble
Old 12-03-2011, 07:28 AM   #5
Beav's Avatar
How old (miles)are your spark plugs?
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 12-03-2011, 07:34 AM   #6
I just bought it in July so I'm not sure. I just had it at the garage and they replaced one in the first cylinder but not the other ones
Old 12-03-2011, 08:16 AM   #7
Fordhartbreaker's Avatar
Sounds to me plugs and wires should really make a difference
Fordhartbreaker is offline   Reply With Quote
Old 12-03-2011, 08:16 AM   #8
Ok I'll try that. Thanks
Old 12-03-2011, 08:17 AM   #9
Np good luck
Old 12-03-2011, 08:46 AM   #10
Beav's Avatar
Plugs are always a good place to start, on a vehicle with more than a few miles and unknown maintenance...
Old 12-03-2011, 08:49 AM   #11
deadsp0t's Avatar
Also you need to be running the correct weight oil, if it's using something like 20w-50 it can make it hard to start when it's cold. If the plugs and wires are bad/worn it would be hard to start all the time.
That's unimpressive
Old 12-03-2011, 09:03 AM   #12
Ok thanks for the info my husband said my spark plugs t new so I'm thinking I should switch the oil
---------- Post added at 11:03 AM ---------- Previous post was at 11:03 AM ----------
What oil should I be using
Old 12-03-2011, 09:49 AM   #13
deadsp0t's Avatar
Don't know for sure but I would guess 5w-30 or 10w-30. If you go to the parts store they can tell you the recommended oil.
That's unimpressive
Old 12-03-2011, 10:53 AM   #14
Ok thanks
starting problem chuck andres 1979-1995 Mustang GT 13 10-11-2011 07:24 AM
Cold Start/ Idling issue CodyNelson 1996-2004 Mustang GT 11 09-24-2011 10:34 AM
Intake Suggestions..... Srohda 2011-2014 Mustang GT 42 09-19-2011 03:56 PM
hard to shift into 3rd vinnygt 1996-2004 Mustang GT 6 06-24-2011 02:31 PM
11:09 AM
