rough idle ??? - Mustang Evolution
Old 12-03-2011, 07:19 PM   #1
98mustang11's Avatar
rough idle ???
Any suggestions on why
98mustang11 is offline   Reply With Quote
Old 12-03-2011, 09:05 PM   #2
Fordhartbreaker's Avatar
Tune up, idle air control motor, throttle position sensor maybe
Fordhartbreaker is offline   Reply With Quote
Old 12-03-2011, 10:25 PM   #3
Yea I planned on cleaning idle control. Throttle body and maf tomorrow ....
Old 12-03-2011, 10:30 PM   #4
Sounds like a good way to start how do u plan to clean tps?
---------- Post added at 12:30 AM ---------- Previous post was at 12:29 AM ----------
 I mean how would u clean the idle air control sensor?
Old 12-03-2011, 10:31 PM   #5
Some site I found shows you how in steps with carb cleaner
Old 12-03-2011, 10:37 PM   #6
O that's cool could u send me the link pls
Old 12-03-2011, 10:44 PM   #7
Yep one sec I'm working
---------- Post added at 11:44 PM ---------- Previous post was at 11:40 PM ----------
http://www.muscularmustangs.com/iac.php
---------- Post added at 11:44 PM ---------- Previous post was at 11:44 PM ----------
Tells you a lot if you read all pages on it
Old 12-04-2011, 07:02 PM   #8
mustangg2000's Avatar
Region: Arkansas
Re: rough idle ???
Bad plug .. or plug wire.. bad coil pack.. idle sensor.. bad vac line..
mustangg2000 is offline   Reply With Quote
Old 12-04-2011, 07:49 PM   #9
Coil pack went out in Feb brand new one on looked like plug wot
Old 12-05-2011, 10:54 AM   #10
Re: rough idle ???
Do your duty and Seafoam the upper intake manifold. suck it in through the pcv valve with a drinking straw placed inside the Seafoam can and hold it up to the pcv valve while running. DONE- Runs great!
Put second can of seafoam in gas tank.
One can runs $7.77 here at parts store or WalMart.
Old 12-05-2011, 12:00 PM   #11
Region: Arkansas
Re: rough idle ???
That's always a good idea ..
Old 12-05-2011, 01:31 PM   #12
Did all that idle is better but think I have a gas leak went about 60 miles today had a full tank now almost on a half
Old 12-05-2011, 02:54 PM   #13
Tune up or depends how you drive.
Blackedout is offline   Reply With Quote
Old 12-06-2011, 01:54 AM   #14
I need to know exactly what it should idle at at a stand stop and on average the mph its suppose to get mods yet besides k&n air filter in stock air box ..... I'm thinking the maf has the oil from the filter on it and is makeing it use more gas
Old 12-06-2011, 01:20 PM   #15
Still* mpg*
Old 12-06-2011, 01:28 PM   #16
Idle is like 900 to 1000 rpm does this help any???
Old 12-06-2011, 01:54 PM   #17
Re: rough idle ???
Yeah, idle is 900 and poor gas mileage like that can indicate a vacuum leak. Possibly around the egr lines. Eventually an ecm code should appear. Normal gas mileage best scenario is 24++ MPG.
Old 12-06-2011, 01:58 PM   #18
Ok idle is right then its about 900 and I figured it and it comes out to 19 mpg drive 80 miles a day that's about 4 gallons a day sound right ??
Old 12-06-2011, 02:05 PM   #19
Depends on how you drive and where you drive.
---------- Post added at 03:05 PM ---------- Previous post was at 03:05 PM ----------
Do you have any engine codes?
Old 12-06-2011, 02:08 PM   #20
Nope and its straight highway to work thats all I ever drive
Old 12-06-2011, 04:05 PM   #21
Sea foam is a miracle love that stuff, also puts on a great show lol
Old 12-06-2011, 05:04 PM   #22
Lol
Old 12-06-2011, 11:04 PM   #23
Re: rough idle ???
Oh yeah, cheap insurance that is re-doing even if you said it has been done is to get two cans of Seafoam, one in tank and one sucked in vacuum line plus replace the fuel filter one more time. It's cheap insurance to help eliminate a little bit of second guessing!
idle problems brian94gt 1979-1995 Mustang GT 22 11-21-2011 08:44 PM
Rough at idle! Ruthless Pre-2005 V6 Mustang 7 11-07-2011 04:24 PM
humming noise during idle robertoortiz85 1996-2004 Mustang GT 6 10-23-2011 02:12 AM
Stupid idle NateNasty 1979-1995 Mustang GT 23 10-17-2011 07:12 AM
Running Rough. ColeJohnson 1996-2004 Mustang GT 25 09-12-2011 03:46 PM
10:27 PM
