Oil for colder temps - Mustang Evolution
Old 12-04-2011, 09:28 AM   #1
Ilovemustangs88's Avatar
What motor oil should I use in my car for winter? It gets below freezing here.
Ilovemustangs88 is offline   Reply With Quote
Old 12-04-2011, 11:00 AM   #2
5w30 would work great for winter temps.
Gtmustang89 is offline   Reply With Quote
Old 12-04-2011, 01:15 PM   #3
davidcseifert's Avatar
Region: Arkansas
Re: Oil for colder temps
Uuumm gtmustang89, do you know what those numbers stand for?
5 is the resistance to flow when warm
30 is the resistance to flow when cold
Unless that is what is required its worse to switch to a heavier oil....
Stick to your factory 5-20 OP...... (unless yours is one of the older sixers that says it requires 5-30, then you use that)
Point being use what the factory specifies and don't f with it.....
blower/new cam soon
Old 12-04-2011, 06:27 PM   #4
Im not so sure you know know a whole lot there the 5w stands for 5 winter so when colder or at startup temp. and the 30 is the operating temp. or at 100 degrees celcius or 212 degrees farenhiet try googleing it you might learn a thing or two
Old 12-04-2011, 08:15 PM   #5
estang85's Avatar
Region: Delaware
Use whatever feels right lol
estang85 is offline   Reply With Quote
Old 12-04-2011, 09:03 PM   #6
Region: Arkansas
f*** brain fart, got the numbers backwards -_- my bad man
the factory standard is what you should use either way OP people seems to have troubles whenever they start changing around the oils......
blower/new cam soon
Old 12-05-2011, 08:17 AM   #7
Thanks
Old 12-05-2011, 10:14 AM   #8
5W-30 Mobil1 Extended Service engine oil. 5W being the important weight information. My car calls for 5w-30, so there are no changes needed.
Oil filters that provide the highest quality anti-drain back valve which ensure oil at start up are:
-Amsoil Ea oil filter has largest best quality
-Royal Purple awesome parts
-K&N and Mobil1 oil filters built great also
FYI- AM now sells all the best oil filters for our cars, check it out. Do research on the website- "bobistheoilguy.com" The test results don't lie!
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 08:51 PM
Oil pressure issues Klinton 1979-1995 Mustang GT 6 09-11-2011 02:52 PM
Off Topic Question - Oil Weight illestdomer2005 Pre-2005 V6 Mustang 7 09-09-2011 10:26 AM
What oil should be used on my cam break in? wc3john 1979-1995 Mustang GT 6 08-15-2011 12:43 AM
88 fox oil leak 04TRV6 1979-1995 Mustang GT 4 07-05-2011 02:17 PM
07:52 PM
