v6 stang - Mustang Evolution
Old 12-08-2011, 10:08 AM   #1
v6 stang
04 v6 mustand can you turbo stock and how long will it last with 6 to 10 psi and what should i do to the motor to make it a litter faster and last with 6 to 10 psi im new to useing turbos and am lost to parst to get for the motor all i really know is high compression pistons and injecters but dont know anything about injecters
lance is offline   Reply With Quote
Old 12-08-2011, 11:08 AM   #2
davidcseifert's Avatar
Region: Arkansas
Re: v6 stang
11psi limit on factory internals....
After that or even still at that max you would benifit in longevity from a forged bottom end (forged pistons and rods but a factory crank can take the beating...)
To boost 11psi you need a new bigger fuel pump (the svt focus 255lph pump is a direct drop in) and I believe it was 39/42 lb injectors for that psi....
High compression pistons are a no no with boost, leave it factory comp or if you plan on doing extreme boost with a forged bottom end get 8.8-low 9's CR
blower/new cam soon
Old 12-08-2011, 11:33 AM   #3
Re: v6 stang
will all that work with 6-10 psi because i want to run six around town and ten to race ill get the programer amd thanks for the info
Old 12-08-2011, 02:14 PM   #4
ESG642T's Avatar
Re: v6 stang
The difference between 6 and 10 isn't going to be that dramatic you could run 10 all the time.
ESG642T is offline   Reply With Quote
Old 12-08-2011, 03:00 PM   #5
Re: v6 stang
ya good point i just want to set it 5 or six for me girlfriend she has never drove bostedand i dont need a blown up cr cause she dose not know what the hell she is doing lol crazy women
Old 12-08-2011, 03:02 PM   #6
ESG642T's Avatar
Re: v6 stang
I wouldn't let a girlfriend drive my car, unless it was more like one of those 4 year girlfriend that you just don't wanna get engaged to yet but you know its coming.
Old 12-08-2011, 04:27 PM   #7
Region: Arkansas
Re: v6 stang
^^^ agreed...........
btw don't you have to spend a couple extra hundred dollars to get a boost controller to change back and forth like that? i'm pretty sure i remember it being just a spring only capable of one setting otherwise
blower/new cam soon
Old 12-09-2011, 09:14 AM   #8
mustangg2000's Avatar
Region: Arkansas
EBay has a boost controller that twists in and out for more or less boost its on the vac lines for under 20 bucks
mustangg2000 is offline   Reply With Quote
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
Choosing a V6 over a V8 Shidifen 2005-2010 V6 Mustang 57 12-02-2011 05:19 AM
07 v6 stang performance adam 2005-2010 V6 Mustang 11 11-01-2011 02:53 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
02:37 PM
