e brake light - Mustang Evolution
Old 12-08-2011, 03:03 PM   #1
blackonblack's Avatar
e brake light
whats up. havn't been on in awhile but im having an issue.. when i floor my car my e brake light pops on then goes back off. its just started recently. what does this mean?
2004 3.9L v6
Black on black on black
MAC Cold Air Intake, 4.10 gears + T-Lok, SCT Tuner, dual H piped flowmaster super 40's
blackonblack is offline   Reply With Quote
Old 12-08-2011, 03:21 PM   #2
I'm going to guess an again just a wild guess... Fuse?
---------- Post added at 04:19 PM ---------- Previous post was at 04:13 PM ----------
My friend has his lights come on... O/d, Emergancy brake, traction light just randomly come on.
---------- Post added at 04:21 PM ---------- Previous post was at 04:19 PM ----------
Mechanic said short in the petal switch.
Blackedout is offline   Reply With Quote
Old 12-08-2011, 03:27 PM   #3
BossMach's Avatar
Intermittent short!
BossMach is offline   Reply With Quote
Old 12-08-2011, 07:49 PM   #4
93slowstang's Avatar
Low brake fluid. That's why it's doing it under acceleration.
Old 12-08-2011, 08:20 PM   #5
davidcseifert's Avatar
Region: Arkansas
Re: e brake light
i'm with this guy ^^^^^^^^^
make sure before it starts sucking air, also check for leaks as to why it would be low (should that be the case)
blower/new cam soon
Old 12-08-2011, 08:32 PM   #6
Where would you look for leaks
Old 12-08-2011, 08:49 PM   #7
Region: Arkansas
Re: e brake light
anywhere in the braking system, could be a rotted line starting to go, loose brake line connection, someone forgot to fully tighten bleeder screw during brake service, etc......
blower/new cam soon
Old 12-08-2011, 08:53 PM   #8
What about pumping your brakes. I have that habit. Where I just press press and press until the pedal doesn't go down anymore. Could this cause harm?
Old 12-08-2011, 08:58 PM   #9
Region: Arkansas
Re: e brake light
just pumping the brakes during what? just randomly sitting there? if so then no, it won't hurt anything
blower/new cam soon
Old 12-08-2011, 09:01 PM   #10
Yeah park and car is off key not even in the ignition.
Old 12-08-2011, 09:13 PM   #11
Filibuster
Light bulb!..+ 1
XXSTEVEO66 is offline   Reply With Quote
Old 12-09-2011, 09:45 AM   #12
Re: e brake light
thanks fellas
2004 3.9L v6
Weird brake thing that happened RVAStang05 2005-2010 Mustang GT 0 11-12-2011 06:51 AM
Lowering the 2012 5.0 Brembo Brake Package avengnd 2011-2014 Mustang GT 33 10-28-2011 07:47 PM
Brake upgrade!!! gvstack 1979-1995 Mustang GT 1 10-27-2011 02:16 PM
Has anyone solved the low brake fluid issue? Pabsny 2005-2010 Mustang GT 5 10-12-2011 09:10 PM
Most Popular Brake Pads Brent 1996-2004 Mustang GT 18 09-18-2011 10:29 AM
09:21 AM
