2 Questions - Mustang Evolution
Old 12-08-2011, 03:07 PM   #1
2 Questions
1.) is it expensive to rebuild a motor
2.) should mileage determine if you should keep modding your ride? If it's like 125k miles?
Blackedout is offline   Reply With Quote
Old 12-08-2011, 04:18 PM   #2
kickerofdoom's Avatar
I have 150k I still mod
Old 12-08-2011, 04:33 PM   #3
Comforting I also seen a 500k mile mustang still running
Old 12-08-2011, 04:36 PM   #4
davidcseifert's Avatar
Region: Arkansas
Re: 2 Questions
mine had 122K+ and i threw a H/C/I setup on it.....
once you cross the 200ish point yeah i wouldn't do anything major, like that but bolt on's never really hurt, and if you plan on just rebuilding it anyways if something happens the stuff will still be there so if you plan to keep it and repair it i say go for it..........
as to the rebuild are we talking stock rebuild or "built?"
blower/new cam soon
Old 12-08-2011, 04:39 PM   #5
Built. Always go for better.
---------- Post added at 05:39 PM ---------- Previous post was at 05:38 PM ----------
Is it expensive to install a cam???
Old 12-08-2011, 04:56 PM   #6
Region: Arkansas
Re: 2 Questions
for built you can keep the factory crank if you want to stay a 3.8 in which case the forged internals are $1400+ on their own then you have a couple hundred on bearings and if you can't do it on your own at least 400-600 in shop labor to assemble it (possibly more) then you have the top end to consider all new gaskets and head bolts $150-$200
cams aren't that bad really aside from the price of the cam, with that much mileage i would recommend you get new lifters (can buy a set of 16 for $115) if you can refrain from damaging them you can reuse your lower intake gaskets but it would be a good idea to silicone the water jackets on the gaskets (both sides), depending on the aggressiveness of the cam you may need new pushrods and valve springs (custom cams can be made to where you can reuse your factory parts if you are tight on cash)
blower/new cam soon
Old 12-08-2011, 04:58 PM   #7
Alright thanks. Might just put heads for now... Does that add power?
Old 12-08-2011, 05:11 PM   #8
Region: Arkansas
Re: 2 Questions
heads alone not a lot, you'll gain some top end hp but too big a port with factory intakes and cam just kinda lacks on the bottom end, do that with some ported intakes and a cam and you'll be rolling......
just save up (even if you buy it in pieces) and do it all at once, no point in tearing into the motor a couple times, just wasting money....
when you get time hit up ESG-642T on here, he does a bunch of work on these V6's and can hook you up
blower/new cam soon
Old 12-08-2011, 05:28 PM   #9
Old 12-08-2011, 05:30 PM   #10
Region: Arkansas
Re: 2 Questions
-_- i said not a lot lol, maybe 10ish on the wheels with nothing else, maybe.....
blower/new cam soon
Old 12-08-2011, 05:31 PM   #11
Ok and thanks
---------- Post added at 06:31 PM ---------- Previous post was at 06:30 PM ----------
And sorry for saying your car sounded like a supra lol
Old 12-08-2011, 05:38 PM   #12
Region: Arkansas
Re: 2 Questions
Originally Posted by Blackedout View Post
Ok and thanks and sorry for saying your car sounded like a supra lol
lol it's alright and no problem....
blower/new cam soon
95 GT questions deadsp0t 1979-1995 Mustang GT 54 11-04-2011 02:16 PM
Tearing apart a 03 mustang.. many questions please inform. Black_Sunshine Pre-2005 V6 Mustang 1 09-15-2011 01:32 PM
Nitrous Questions Murdered_Stang 2005-2010 Mustang GT 2 07-19-2011 12:00 AM
general 98 questions bradh2414 Pre-2005 V6 Mustang 14 07-08-2011 11:01 AM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 10:55 PM
11:45 PM
