Wierd sound - Mustang Evolution
Old 12-08-2011, 11:46 PM   #1
Wierd sound
So when I'm going slow like through a parking lot I get this hollow rubbing sound coming from the rear of the car. It usually happens when making tight left turns. My car is lowered if that helps. Any ideas on what it could be?
Stubzmekenzie is offline   Reply With Quote
Old 12-09-2011, 01:43 AM   #2
phobik's Avatar
Could be ur tire is rubbing.
phobik is offline   Reply With Quote
Old 12-09-2011, 09:40 AM   #3
shipwreck_98's Avatar
Re: Wierd sound
+1
shipwreck_98 is offline   Reply With Quote
Old 12-09-2011, 06:41 PM   #4
davidcseifert's Avatar
Region: Arkansas
Re: Wierd sound
Are you positive that it's coming from the rear?
What size tires are on there? If they are factory you shouldn't be rubbing, unless something is messed up (front tires)
the rear shouldn't rub at all even with bigger tires, people put 315/35-17 tires on the rear of lower cars without any problems.....
blower/new cam soon
Old 12-09-2011, 07:11 PM   #5
MMVEC's Avatar
Are you sure it's coming from the rear? How many miles do you have on the car? You probably need a new wheel bearing 'or' you should check the rear diff. Is your rear gear stock? If not, who installed it? If you have any aftermarket rear gear, if it's not installed properly without the right amount of spacing/backlash you could wear out the gear. The right way to check your rear end is to put the car on a lift, turn on and have someone put the car in gear while it's up in the air. A good mechanic will have a stethoscope and will be able to hear if the gear is grinding.
MMVEC is offline   Reply With Quote
Old 12-10-2011, 05:29 PM   #6
It seems to be coming from the rear, I have 73k on the car and my tires are 275/35/17. I di have aftermarket gears but they came with the car.
---------- Post added at 05:29 PM ---------- Previous post was at 05:25 PM ----------
Could it be suspension related?
Old 12-10-2011, 07:36 PM   #7
Region: Arkansas
Re: Wierd sound
My self, I would get the rear checked out since its been tore into before.....
blower/new cam soon
how could i make my 2000 v6 mustang sound louder!?? betocruzazul Pre-2005 V6 Mustang 29 01-02-2012 01:41 PM
Sound when shifting at high sppeds! deaser84 2011-2014 V6 Mustang 12 12-07-2011 05:14 AM
Popping sound while braking... 12GTstangCS 2011-2014 Mustang GT 4 11-29-2011 12:55 PM
Deep Sound 559Danny 1996-2004 Mustang GT 10 09-29-2011 06:09 PM
03:34 PM
