auto tranny - Mustang Evolution
Old 12-09-2011, 08:55 AM   #1
kickerofdoom's Avatar
Which is the best brand to get and how hard to install(a tranny cooler)
Old 12-09-2011, 06:23 PM   #2
davidcseifert's Avatar
Region: Arkansas
Re: auto tranny
I'm just gonna buy a cheap one from summit, at least a 6 pass, they had 8 pass coolers for $45 and it comes with the install hardware, some of them even came with the high temp hose you need to bridge it from the factory lines
Install is decently easy just use the zipties that come with it to attach it to the ac condenser or some come with metal brackets that allow you to attach it to the rail running across the from that the radiator brackets are attached to
You'll have to cut the factory fittings off the trans cooler lines just use a regular pipe cutter that you spin around it to cut it, will be a little cleaner cut
Then after that just connect the lines with the hose to the cooler, not hard really....
blower/new cam soon
any auto guys wish was manual? wnt2gofst 2011-2014 Mustang GT 39 10-22-2011 03:26 PM
Auto tranny Dogstang Pre-2005 V6 Mustang 4 10-19-2011 07:56 PM
Tranny question. NV Laser Red 1979-1995 Mustang GT 19 09-13-2011 05:52 PM
Auto to Manual swap? BrKu789 1996-2004 Mustang GT 9 07-17-2011 09:17 PM
4.2 tranny 3.8boii Pre-2005 V6 Mustang 2 07-17-2011 02:45 PM
12:52 PM
