lower degree thermostat worth it - Mustang Evolution
Old 12-12-2011, 08:39 AM   #1
kickerofdoom's Avatar
Is putting a 180 degree going to make a difference or should I leave the stock alone
Old 12-12-2011, 09:02 AM   #2
Dancobra75's Avatar
I'm a firm believer in that cooler your engine can operate the more power and the longer your engine will last, I use 160 stats, I mean do you really need an engine to run 180 to 200 or more to make your heater good enough, and people say that your sensors won't work right without running at that temp, I never had a problem and I do it to every stang I get
Dancobra75 is offline   Reply With Quote
Old 12-12-2011, 09:03 AM   #3
aegischief's Avatar
Leave it stock. Unless you really start with heavy mods, the stock one is going to be best for ya.
aegischief is offline   Reply With Quote
Old 12-12-2011, 05:26 PM   #4
ESG642T's Avatar
Re: lower degree thermostat worth it
180 is fine, anything below that is unneeded.
Things that don't belong on a Mustang: 20+" wheels, altezza lights, halo headlights, neon underglow, body kits that don't come from saleen or roush.
ESG642T is offline   Reply With Quote
Old 12-12-2011, 06:35 PM   #5
davidcseifert's Avatar
Region: Arkansas
Got a 180 in mine, swapping it with a stock one for the winter since it takes 20mins to warm up....
blower/new cam soon
Thermostat Housing Tj88mustang 1979-1995 Mustang GT 8 11-27-2011 08:38 PM
11:17 AM
