grind sound on start up - Mustang Evolution
Old 12-14-2011, 10:55 PM   #1
austinknoll's Avatar
I have this weird noise when I turn on my car. It sound like something is grinding on something in the engine but after I turn over the motor it goes away. Help please! Thanks
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 12-15-2011, 01:25 AM   #2
deadsp0t's Avatar
Every time you start it? Hot? Cold? If its an all the time issue it's likely the starter and/or flywheel teeth becoming worn. Should be able to pop the starter off an take a look at both of them with a flashlight and check the teeth for damage.
That's unimpressive
Old 12-15-2011, 11:23 PM   #3
It's just on cold startup it sounds really weird
---------- Post added at 01:23 AM ---------- Previous post was at 01:23 AM ----------
It's right after the engine turns on
65 Mustang coupe
Old 12-15-2011, 11:59 PM   #4
Alot of a/c compressors can give a loud grunt that you can feel right after startup. It's pretty normal. If it doesn't do it without the defrost or A/c on don't worry about it. My 06 f150 did it from new.
FordTech is offline   Reply With Quote
Old 12-16-2011, 07:59 AM   #5
It's more of like a higher pitched grinding noise for about a second after the engine turns on
65 Mustang coupe
Old 12-16-2011, 09:19 AM   #6
Rascal's Avatar
Re: grind sound on start up
i had this problem for a while then me eng light came on turns out my "distributor" was going bad. i think it was called a cam position sensor.. was about 85 bucks :/.. it would do it no mater hot or cold every time i started it, and i kept getting worse till the cel came on.. was a pretty easy fix tho
Rascal is offline   Reply With Quote
Old 12-16-2011, 11:46 PM   #7
Mine does that too pretty consistently hot or cold. never knew what that was, thanks.
how could i make my 2000 v6 mustang sound louder!?? betocruzazul Pre-2005 V6 Mustang 29 01-02-2012 01:41 PM
Sound when shifting at high sppeds! deaser84 2011-2014 V6 Mustang 12 12-07-2011 05:14 AM
Cobra will not start drusmith General Mustang Discussion 14 11-28-2011 06:06 PM
Car wont start Joed935 Pre-2005 V6 Mustang 5 11-13-2011 05:50 PM
1995 3.8 l v6 mustang wont start. Help Please zmckibbin Pre-2005 V6 Mustang 7 09-19-2011 12:29 AM
07:55 PM
