Starter..Altenator..or both? - Mustang Evolution
Old 10-26-2007, 02:16 PM   #1
MuStAnGcHIk88's Avatar
Send a message via Yahoo to MuStAnGcHIk88
Question Starter..Altenator..or both?
Ok guys here is my question of concern.. the other day the mustang wouldnt start, so right off i figured the battery was bad..it is kinda old..so i got a new one.. put it in and the car still wouldnt start..ok..so i was wondering could it be the starter or altenator or both? It sounds like it wants to turn over but it doesnt..it just clicks. The car still is dead though with the new battery which is confusing me, the battery level in the car is midway like it should but when u go to start the car nothing turns over..what could be causing this?
My V6 might not go as fast as your GT but she goes fast enough so that when I go by you only WISHED you had her!
MuStAnGcHIk88 is offline   Reply With Quote
Old 10-26-2007, 02:57 PM   #2
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: Starter..Altenator..or both?
Of the 2, it should be the starter. If the alternator were bad, the car would still crank and run off just the battery alone for a period of time (until it wears down).
DarkShadow is offline   Reply With Quote
Old 10-26-2007, 07:20 PM   #3
ok...c i was telling my friend that ( of course he thingks heknows all) that an alt. doesnt run until the car is started..but u know how "know it alls" r..lol
Old 10-26-2007, 09:37 PM   #4
Aidan_04's Avatar
It's your starter, an easy fix for most Fords is to get someone under the car to tap on the starter a few times while someone else tries to crank the engine, this will normally get it going. Fords are notorious for this.
2004 redfire 4.6L GT / 1994 rio red v6 vert / 1990 7UP LX vert
2804
^^^my fave V8 chick ^^^
Old 12-03-2007, 10:42 AM   #5
That Is Very True It Could Have A Bad Spot And If You Hit It It Will Crank. See Your Altenator Just Charges The Battery Back Up And If Your Altenator Went Bad You Would Have Heard A Wining Sound When You Cut It Off And Cold Only Make It Maybe 2 Miled Own The Battery Before Having To Jump It Back Off. So It Deff The Starter The Electricity From The Battery Goes Diretly To The Starter Plate Which Engages The Starte To Crank The Car When It Cranked The Belt Turns The Alternator Pull Which Charges Up The Battery. So If It Wont Crank It The Starter.especially If It Is A Continous Click One Or Two Clicks Could Be A Bad Battery If It Trying To Turn And Clicks It The Starter.
customsixstang is offline   Reply With Quote
Old 12-03-2007, 08:36 PM   #6
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
Well I have not had this problem with my stang, but my old f 150 would not start one day and it turned out to be the stator. this is also a cheap quick fix. FYI on stators NEVER GET THE CHEAP BRAND. they will always fail. I found this the hard way, a few times.
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Starter not working? blue-saleen Pre-2005 V6 Mustang 7 07-19-2010 08:48 PM
starter question iwannagofast 1996-2004 Mustang GT 0 03-31-2010 10:03 PM
1987 GT altenator will not charge??? PLEASE HELP!!! ERIC1987GT 1979-1995 Mustang GT 4 03-18-2010 09:06 AM
starter 95gt45 1979-1995 Mustang GT 5 05-30-2008 06:53 PM
Starter wkndpaintballer Pre-2005 V6 Mustang 21 03-01-2007 02:21 PM
12:06 AM
