Block Strength? - Mustang Evolution
Old 10-26-2007, 09:00 PM   #1
Block Strength?
Sup guys, got a question. How much hp will my 02 block hold. Right now im pushing just under 300 rwhp with 13.5 pounds from a p-1sc. But this winter I was planning to swap out the upper end and cams with a stage 3 kit from supersix. They say it will give a 90+ hp increase. Right now Im shifting at about 5800rpm. Id appreciate some light on the subject since there are no other sixers around my town. The people I have talked to said the stock block can only hold 400hp. thanks
missin2 is offline   Reply With Quote
Old 10-26-2007, 10:32 PM   #2
Aidan_04's Avatar
Re: Block Strength?
Your block will be fine, what you want to upgrade will be your rotating assembly. I would definitely look into forged internals...especially with 13.5 lbs of boost, that's pushing the limit.
2004 redfire 4.6L GT / 1994 rio red v6 vert / 1990 7UP LX vert
2804
^^^my fave V8 chick ^^^
Old 10-27-2007, 03:47 PM   #3
rydog's Avatar
Send a message via MSN to rydog
Re: Block Strength?
Well Matt from Delk performance is running about 700hp on a stock block if that says anything
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 10-27-2007, 04:16 PM   #4
Kiljosh's Avatar
Re: Block Strength?
Actually, last time I heard, A v6 block has never broken. Its always the internals that go.
Makes me proud.
Old 10-27-2007, 04:19 PM   #5
Re: Block Strength?
Makes me proud.
Must not be pushing enough power through it.
JROC is offline   Reply With Quote
Old 10-27-2007, 04:37 PM   #6
Kiljosh's Avatar
Re: Block Strength?
cast iron baby
Old 10-27-2007, 05:20 PM   #7
Re: Block Strength?
I would say 500 or so for the block~ no one really knows some are far over and some are under and they go... just depends on how you treat it.
Old 10-27-2007, 06:10 PM   #8
Re: Block Strength?
Thanks for the info. But would there be a significant price difference if i were to drop in stock forged internals w/ main girdle vs. maybe a forged stroker kit (boring, etc.). Im trying to minimize the amount of times I tear apart the block ( Even though i do so every winter). Im not a big fan of wasting money if I do have to though either.
Old 10-27-2007, 06:23 PM   #9
Send a message via AIM to white95v6
Re: Block Strength?
the blocks soo far seem realy strong. its the stock rods and pistons suck. putting a main girdle on one will not help if you still have stock rod and pistons.
my suggestion is to do good rods and pistons with a Real main girdle(not a stock one) main studs, head studs. and all the good parts to complemnt your combo.
at 13.5 psi you realy should be making more then 300rwhp unless you have no other mods and its a auto with a REALY safe tune.
also look into
rpm-mustangs.com.
they both also carry what you are looking for.
The First and Only 9 Sec Production Based V6 Stang!!,First over 500rwhp,First and only over 600rwhp
60ft-1.42,1/8th mile-6.25@111mph,1/4 mile-9.83@136.65mph
Sponsored by:
WWW.DELKPERFORMANCE.COM
white95v6 is offline   Reply With Quote
Old 10-27-2007, 10:17 PM   #10
Re: Block Strength?
Yea since Im shifting at 5800rpm I have a pretty safe tune. It runs a little rich too, which doesnt help the hp any. But I think the place that I took my car to get tuned was inexperianced with mustangs or something. Seeing as my Pony is descently moded. I have a full exhaust w/ bbk shorty headers, bbk 94-95 gt o/r h-pipe(moded by cutting and welding shut the cross pipe), summit 2.5 catback w/ aero chamber mufflers from hooker. Also a fully built rearend w/ 4.10s and traclok, built auto tranny w/ stock gears. ignition from performance distributers. What numbers should i be looking at. Last time I ran it she ran a 13.21 at 111mph.
Old 10-27-2007, 10:57 PM   #11
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: Block Strength?
As others have said, the block is the last thing you'll have to worry about. It's the bottom end.
DarkShadow is offline   Reply With Quote
Where to get a 4.2 block Zebs5408 Pre-2005 V6 Mustang 10 02-27-2010 02:46 PM
5.0 on a 4.6 block. DaDant! 1996-2004 Mustang GT 2 02-06-2009 09:35 PM
New Orleans Levees to be left at old strength PureVenom The Bar 3 10-06-2005 03:40 PM
4.2 Block n8r Pre-2005 V6 Mustang 5 06-12-2004 11:10 AM
91 Block the same as 94+? Brent Pre-2005 V6 Mustang 10 11-07-2003 09:13 AM
07:39 PM
