Gt hood scoop!! - Mustang Evolution
Old 12-20-2011, 07:06 PM   #1
Venomouz831's Avatar
Gt hood scoop!!
Hey guys I want to get a gt scoop on my car and I was wondering if it is easy to install on my car any help would help lol
)02 Gt, Founder of WE2G
Old 12-20-2011, 07:30 PM   #2
davidcseifert's Avatar
Region: Arkansas
Re: Gt hood scoop!!
the factory scoops come with studs that stick out of it that you have to drill into the hood for, just be very careful you don't have much room to work with if you screw up, the way i usually see it done is sitting it on the hood and line it up properly and trace around the studs very closely, then drill out the inside the marks and it should slip right in and if you lined it up right it will sit perfectly in the groove...
blower/new cam soon
Old 12-21-2011, 12:53 AM   #3
Re: Gt hood scoop!!
another trick to making sure you drill the right spot...put some grease on the ends of the studs and slowly drop it in place...let the grease mark the spots for drilling...this trick is also great for drilling hood pin holes
SonicBoom239 is offline   Reply With Quote
Old 12-21-2011, 02:52 AM   #4
Re: Gt hood scoop!!
3M double sided tape + 100mph on the highway = install complete.
New edge 232 is offline   Reply With Quote
Old 12-21-2011, 02:54 AM   #5
Re: Gt hood scoop!!
bad...very bad rich...
Old 12-21-2011, 02:56 AM   #6
Re: Gt hood scoop!!
What? The speed is to make it so air pushes down on the scoop so the tape gets an extra grip on the hood.....
Old 12-21-2011, 02:56 AM   #7
Re: Gt hood scoop!!
do i have to make a BB thread about your 3m obsession on MM
Old 12-21-2011, 02:57 AM   #8
Re: Gt hood scoop!!
You sir... Just ruined everything.
Old 12-21-2011, 03:03 AM   #9
Re: Gt hood scoop!!
What....about mustang mafia....that is what mm stands for right
Hood scoop issues? Dubya11 General Mustang Discussion 3 12-13-2011 06:06 PM
Hood Winked Tj88mustang 1979-1995 Mustang GT 14 11-24-2011 06:42 AM
I want a GT Hood! ramosjose16 Pre-2005 V6 Mustang 30 11-18-2011 07:09 PM
Gt hood ? 2001mustang Pre-2005 V6 Mustang 3 11-17-2011 10:46 PM
2007 factory hood with scoop mustangchassy Mustang Parts for Sale and Wanted 0 07-24-2011 10:42 AM
08:35 AM
