split port swap on 98 - Mustang Evolution
Old 12-21-2011, 02:43 AM   #1
KM98Stang's Avatar
How do I make this happen? Cost? HP gain??
KM98Stang is offline   Reply With Quote
Old 12-21-2011, 02:46 AM   #2
Re: split port swap on 98
cost depends on location and if you can find a donor engine at a salvage yard or on CL...around here you can usually find all the upper parts you need for around $200...
as for hp gains...expect to have the same as a 3.8/3.9L so nothing crazy
SonicBoom239 is offline   Reply With Quote
Old 12-21-2011, 02:48 AM   #3
davidcseifert's Avatar
Region: Arkansas
i actually have a set of heads, the lower intake, and an 4.2 F-150 fuel rail if you want to buy it, send me a pm if serious
blower/new cam soon
Old 12-21-2011, 02:49 AM   #4
KM98Stang's Avatar
Sooo I'd need to find a 99, take the upper intake manifold and the heads... would I need the pistons too?
Old 12-21-2011, 02:49 AM   #5
David is a good guy so don't be afraid to look into his parts
Old 12-21-2011, 03:28 AM   #6
Region: Arkansas
http://lmgtfy.com/?q=mustang+V6+split+port+swap
blower/new cam soon
Old 12-21-2011, 03:32 AM   #7
another viable option to consider is an m90 swap from a super coupe...research it a bit and you might find it more to your likeing
Old 12-21-2011, 03:37 AM   #8
Region: Arkansas
Let me google that for you
yeah i'm bored lol
blower/new cam soon
Old 12-21-2011, 06:03 AM   #9
bmabbott's Avatar
I'm doing that swap at the moment.... and let me tell you... it takes a LOT more work than you would think. It's not a simple swap for my 98. Especially since I had the blower,intake, heads, and fuel rail to start with and am now searching for all the missing goodies...
If you do this swap... just find a Supercoupe donor first, and then do the swap... so you know all of the parts are there.
But this m90 swap on stock internals will only give you about the same HP gains as a split port swap... so get forged internals if you do this so you can run higher boost! That's my rant for the day. haha
*01 Cobra, 4.6L, P&P heads, Stage 3 comp cams, MAC LT headers, O/R Hpipe, Bassani catback exhaust, Too many bolt-ons to list..., 4.30 gears. (364 rwhp/ 330 rwtq)
*01 Roush Stage 2, 4.6L, 5 spd, BBK Bolt-ons (Wife's)
*71 Chevelle, 350, 4 spd, H/C/I, (~400 hp)
*72 C10, 350, Auto, (my Daily Driver)
bmabbott is offline   Reply With Quote
Old 12-21-2011, 11:42 AM   #10
Region: Arkansas
You can run up to 11psi safely on the factory internals, don't be afraid to turn it up some.....
blower/new cam soon
Old 12-21-2011, 12:44 PM   #11
i know it involves work...i've helped on a friends super coupe lol. i agree on the donor car...
Old 12-22-2011, 11:58 AM   #12
KM98Stang's Avatar
Soooo for the price I can get a SC engine or car for.... I could get the 4.6L dohc engine for 800...
Old 12-22-2011, 12:03 PM   #13
wtf you gonna do with a 4.6 4v ?
spend more on accessories, K member, wiring harness, cooling system, transmission, ds, rear end, ECU, Guages/Pats, fuel systems ...
Then you gotta put the **** in ... and hope your sixer suspension supports it well enough ...
So I hope you can do all the work yourself ...
Enjoy that $800 4v swap
To OP
Good Information Thread.
Enjoy reading and researching
SenorMike is offline   Reply With Quote
Old 12-22-2011, 12:13 PM   #14
KM98Stang's Avatar
To OP
I mean I can do all of the work my self, with my dads help of course. But your definitely right on all the extras I'd need to get to support the v8...but truthfully its a project car so my pay checks will get dumped into it haha do you think with the m90 swap and with a few more mods it'll challenge some gts?
Old 12-22-2011, 12:19 PM   #15
dude my N/A set up challenges them. Do the m90 with a better IC and cam. Get a 93-94 4th Gen m90 set up, and do some porting even mild done by yourself to the heads and intake, and a good exhaust w/ LT's and O/R if possible ... you'd spank GT ***. Probably play w/ the 4.6 3v or the N/A 4v mach1's and 98 cobra. Not sure on that last sentence but probably a good change idk
Old 12-22-2011, 05:07 PM   #16
KM98Stang's Avatar
Should I swap engines or just the heads, fuel rail and m90?
Old 12-22-2011, 05:18 PM   #17
Region: Arkansas
You can get an entire engine for a grand or less usually so its not much hassle, plus the supercoupe is halfway forged lol
blower/new cam soon
Old 12-22-2011, 05:24 PM   #18
ive seen the full engine for like 400ish before ...
Basically in the swap you'd either do the whole engine, or swap everything above the block out
Old 01-24-2012, 10:07 PM   #19
KM98Stang's Avatar
Did a little research, the new edge 1999 3.8 split port was rated at 190hp, 40+ then my 1998 single port. I'd get that much of a gain with the swap?
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 08:51 PM
V8 engine swap Venomouz831 Pre-2005 V6 Mustang 12 12-10-2011 08:32 PM
Installing a supercharged 3.8 from a thunderbird SC into my 99 mustang skip318 Pre-2005 V6 Mustang 12 10-01-2011 10:03 PM
irs to sra swap Black99Snake SVT Mustang 4 08-23-2011 10:41 PM
Pi engine swap Kurlywhiteboy 1996-2004 Mustang GT 0 08-14-2011 10:48 PM
01:51 AM
