Rear Shock Tower Brace - Mustang Evolution
Old 12-21-2011, 02:20 AM   #1
so i'm making a RSTB out of an '05+ panhard bar my friend gave me last month when he bought a GT500 (he didn't need it anymore lol)...
I've drilled out the beads and have ground down the bearings on either side so i can weld them into place...i know at this stage it would be strong enough to do the job well. however i'm contemplating adding in some triangle pieces from the bar to the shock tower to add some extra strength...
Anyone on here have a RSTB on their sixxer and if so does yours have extra bracing or do you consider the bar by itself more then enough.
---------- Post added at 03:20 AM ---------- Previous post was at 02:58 AM ----------
heck this can include even the GT guys if they lurk this section and see this thread...
SonicBoom239 is offline   Reply With Quote
Old 12-21-2011, 02:21 AM   #2
davidcseifert's Avatar
Region: Arkansas
Re: Rear Shock Tower Brace
i wouldn't bother putting anything else in there unless you don't feel confident that you can get enough contact area to weld the bar in, in that case yes add some small-ish supportive plates to ensure you don't have any torsion/tension ripping the welds apart.....
blower/new cam soon
Old 12-21-2011, 02:29 AM   #3
that was my next concern...this car does see the Dragons Tail quite a bit...and i know a road doesn't sound like much of a challenge...it can be just that. To give an idea on how crazy it gets....here is a picture of my car with stock suspension just coming off of a curve about to hit another one (thank god for upgraded brakes)...
Uploaded with ImageShack.us
Old 12-21-2011, 02:34 AM   #4
Region: Arkansas
it's rocking side to side a little haha it couldn't hurt if you have the time to do a little extra support to it, if you have a welder and a good cutter for the extra metal it would be a small task anways...
blower/new cam soon
Old 12-21-2011, 02:36 AM   #5
yeah it's shifting quite a bit...which is why i love those photographers that stand there all day taking pics of the cars and bikes taking that road. Good way to see how it's coping with the turns....of course it was worse for the guy in front of me that would kick his rear on every turn...he had a 99 v6...only difference is i have a solid rear sway bar from a GT...he didn't
Old 12-21-2011, 02:45 AM   #6
Region: Arkansas
yeah if i ever find a gt at the junkyard i'm getting a rear sway bar for mine, i know they work from 79-04 but the question i have which gt sway bar is the best, i know the cobra's are obviously the better choice, but......that's like trying to find a needle in a haystack around here, didn't some of the gt's come with better (thicker) sway bars than others? (certain years)
blower/new cam soon
Old 12-21-2011, 02:48 AM   #7
yes some GTs had solid bars and some had hollow bars...i've passed up a few hollow bars until i found a solid one for $30 from a friend that works for a mustang performance shop here in TN. I also need to hit them up for a set of FLSFC...but that's going to have to wait till the new year. I'm selling my Saleen spoiler to a guy on MM that lives in TN so i should have the money then to get some things set.
It's funny because i'm making this car to handle and brake way better then factory..then come may i won't even be driving it...since i'm giving it to my fiance. I really don't need to drop to much into this car lol
Old 12-21-2011, 02:56 AM   #8
Region: Arkansas
stupid question i'm sure but are they hollow enough to where you can hit it with a wrench and hear the hollow sound still? i'm assuming the newer the better on the chances of it being a solid one?
so you going to get another GT this time around or are you going a different route?
blower/new cam soon
Old 12-21-2011, 03:05 AM   #9
You can desk the weight of it and tell...I never thumped it so I can't tell to that.
As for what's next...either another GT or if my friend was serious about selling his car come spring a sonic blue svt focus.
Old 12-21-2011, 03:07 AM   #10
Region: Arkansas
get the stang -_- ........................ lol
blower/new cam soon
Old 12-21-2011, 03:11 AM   #11
I might....either way it will be a dd/track car. The focus would be nice though with a nice turbo setup like rdy4war has....but ill most likely get the GT....depends on funds...come spring time he would sell the focus just to get out of the payments lol...which only have about 6k left
Old 12-21-2011, 04:37 PM   #12
a v6 doesnt have enough power to rip the welds apart on launches oh wait....im in the wrong thread. carry on.
Just a Six
v6procharged is offline   Reply With Quote
Old 12-21-2011, 04:59 PM   #13
i'm not worried about the power causing problems but the stress of 311 curves at speed...i really love this road
Old 12-21-2011, 05:07 PM   #14
word. why weld the RSTB when they bolt in...
Just a Six
Old 12-21-2011, 05:09 PM   #15
i made my own out of an '05+ panhard bar so bolting it in might not be an option...the ends do have mounting holes there from where the bearing were in there that i took out. once i pull the carpet out i should be able to see if it'll mount or not without welding.i know it's wide enough to fit because a guy on MM has done this...but i can't find his thread to see if it's bolted or welded
Old 12-21-2011, 05:12 PM   #16
i would just bolt it in, im sure it wouldnt be too hard to figure it out. that way it can be removed, easily lol.
Just a Six
Old 12-21-2011, 05:22 PM   #17
hmm i may have to drill some mounting points if i have to...wouldn't be hard
Old 12-21-2011, 05:33 PM   #18
couldnt bolt it on the shock tower like the rest of them? take off the nut, stick it on, then put nut back on.
Just a Six
Old 12-21-2011, 05:50 PM   #19
Region: Arkansas
Lol it's not made for his car Brandon.... It's not a direct fit application
Edit: I like the new sig Wendell, maybe they'll understand..... Lol
blower/new cam soon
Old 12-21-2011, 05:55 PM   #20
i know this. it has holes where the bearings used to be, its long enough to go across, if too long cut it and weld it back together, put it on like it was made for the car. all you need is a bar with a hole on each end. not too hard.
Just a Six
Old 12-21-2011, 06:13 PM   #21
Region: Arkansas
You could do that, but you would have to be sure to weld up the bar very carefully, I guess you could grind it down and repaint to make it look good
blower/new cam soon
Strut tower brace Travis B 1979-1995 Mustang GT 4 12-09-2011 06:58 PM
Rear end clunk Brad.krieg SVT Mustang 3 12-08-2011 12:05 AM
Strut Tower Brace RVAStang05 2005-2010 Mustang GT 10 11-26-2011 12:03 PM
2012 GT strut tower brace smokeater1 2011-2014 Mustang GT 22 11-19-2011 08:35 AM
Rear end swap bmabbott Pre-2005 V6 Mustang 9 10-01-2011 12:14 AM
11:37 PM
