Spacers!! - Mustang Evolution
Old 12-22-2011, 11:23 PM   #1
Venomouz831's Avatar
Spacers!!
So I just got my spacers for both front and back. There's really nothing to it right just put em on. Do I need to get an alignment or something
)02 Gt, Founder of WE2G
Old 12-22-2011, 11:28 PM   #2
davidcseifert's Avatar
Region: Arkansas
Re: Spacers!!
why are you putting spacers on the front of the car?
simple as inserting the spacers unless they are thick enough to require changing around of other things like studs for the lug nuts or anything else
no alignment required, they just make the tire sit out further not lean any (unless they are cut crocked)
blower/new cam soon
Old 12-22-2011, 11:49 PM   #3
Re: Spacers!!
im curious about your front issue as well....as for the rears...what's the size of your spacers
SonicBoom239 is offline   Reply With Quote
Old 12-22-2011, 11:58 PM   #4
I got all four cuz a buddy of mine sold em to me cheap. On the back I think they are 25mm and front 10mm
Old 12-23-2011, 12:01 AM   #5
Re: Spacers!!
maybe lowered and big wheels it might be a good idea, but if your not having any rubbing issues up front dont use them.
Backs, go for it.
SenorMike is offline   Reply With Quote
Old 12-23-2011, 12:03 AM   #6
Why is it bad if I put em on the front
Old 12-23-2011, 12:07 AM   #7
Re: Spacers!!
oh those are the cheapy's from Advance and Autozone....honestly i wouldn't put them on my car....i tried those small ones on my old v6 and i hated how the made the car feel....now if you had bought hubcentrics then i'd give the go ahead on the rear
Old 12-23-2011, 12:08 AM   #8
Re: Spacers!!
smart man for the most part, done lots of crap to stangs
And the fronts just wont look good pushed out like that ...
Old 12-23-2011, 12:09 AM   #9
It's a brand name is bully
Old 12-23-2011, 12:14 AM   #10
Re: Spacers!!
if they aren't hubcentrics then it doesn't matter the name on them to me...i won't run anything but because i've had a wheel fly off on me on the hwy before on another stang...and after that anything i put between my wheels and hub must be top notch quality...hubcentrics are just that...
can you post a pic of what you bought...also have you test fit yet to see if you can put them on with your current studs...you don't want to skimp out on the amount of stud thread you leave for the nuts...if your current studs are too short you'll need to press them all out and get longer ones
Old 12-23-2011, 12:17 AM   #11
Yea I'll post some up tomorw and I know they'll fit my friend had em on his mustang for 2 years and we have the same mustang and nuts
Old 12-23-2011, 12:18 AM   #12
Re: Spacers!!
i bet they won't be hubcentrics....but if you want to run them go ahead.
Old 12-23-2011, 12:19 AM   #13
I don't knw if they are or not but ima put em on tomorw
Old 12-23-2011, 12:19 AM   #14
Re: Spacers!!
good luck
Old 12-23-2011, 04:23 AM   #15
Brad.krieg's Avatar
Send a message via Yahoo to Brad.krieg Send a message via Skype™ to Brad.krieg
From experience, i reccomend wider wheels and tires. Ford designed them that way for a reason. When u add spacers it puts stress on parts an can cause pre mature wear. Not to mention those spacers are crap. If you need to run them use hubcentric and only in the back. I wouldn't go more than an inch (25mm). Especially with a solid axle. AM has sime german ones that should be ok. Dont get those chineese ones. Made tht mistake before...
Brad.krieg is offline   Reply With Quote
Old 12-23-2011, 07:09 AM   #16
Fordhartbreaker's Avatar
Spacers are a no no in the front it's way to hard on ball joints and wheel bearings don't do it man!!!!! Just the back!!!
Fordhartbreaker is offline   Reply With Quote
Old 12-23-2011, 11:57 AM   #17
Justasix98's Avatar
Agreed, just the back. Also look into tires as well. I had the factory wheels on mine and hated them! (225/50/16). I sold those rims & tires for $150 and bought a set of 00' GT rims (255/40/17). Not only did it make my car look 10x better but it changed everything as well. Braking was one of the first things I noticed. Stopped a lot quicker, overall everything handling wise was improved drastically.
Just A Sixxer!
Proud member of WickedStangs Okc Chapter!
Justasix98 is offline   Reply With Quote
Old 12-23-2011, 01:40 PM   #18
Before
Old 12-23-2011, 01:40 PM   #19
After
Old 12-24-2011, 10:44 PM   #20
southfour's Avatar
Re: Spacers!!
i would defiantly not put them on if they are not hubcentric
southfour is offline   Reply With Quote
Old 12-24-2011, 10:47 PM   #21
Re: Spacers!!
and he installed them lol...everyone trying to tell him otherwise, but he does it anyways...what is this world coming to lol
no pics btw of the spacers before install....
Old 12-24-2011, 10:49 PM   #22
My buddy had em on his car for 3 years and never had any complaints so for them being great for that time ima trust em
Old 12-24-2011, 10:52 PM   #23
Region: Arkansas
Re: Spacers!!
i thought it was 2 years? lol
blower/new cam soon
Old 12-24-2011, 10:53 PM   #24
Or watever 2,3 years
Old 12-24-2011, 10:53 PM   #25
Re: Spacers!!
years change when trying to prove a point..
So OP i'm guessing they weren't hubcentrics since there wasn't a pic of them posted
Old 12-24-2011, 10:55 PM   #26
They were painted that's why their like that
Old 12-24-2011, 10:56 PM   #27
Re: Spacers!!
Attachment 36569
not hubcentrics..unless due to the paint i can't see a ring around the center hole...is there a lifted point there?
Old 12-24-2011, 10:58 PM   #28
They work solid for me
Old 12-24-2011, 10:58 PM   #29
Re: Spacers!!
that's not answering my question....it's a simple yes or no answer. i don't see why you're being difficult lol
Old 12-24-2011, 10:59 PM   #30
Clean
Old 12-24-2011, 11:00 PM   #31
Lol I replied at the same time before I seem ure q's n no
Old 12-24-2011, 11:01 PM   #32
Re: Spacers!!
well...best of luck then.
Old 12-24-2011, 11:01 PM   #33
I have faith in em as I've had in all my car parts
Old 12-24-2011, 11:02 PM   #34
Re: Spacers!!
lol
Old 12-25-2011, 05:54 AM   #35
Brad.krieg's Avatar
Those will work. But i would reLly really recomend buying new hubcentric ones. All the weight will be on those crappy studs tho. Just keep em tight. Even more reason to get new ones if they are hella old. U have a nice car, dont put iffy parts on it.
Spacers help! Venomouz831 Pre-2005 V6 Mustang 0 12-05-2011 09:41 PM
Wheel Spacers? UMSaleen Pre-2005 V6 Mustang 1 12-03-2011 08:28 AM
Quality wheel spacers Brad.krieg Mustang Wheels & Tires 6 11-21-2011 06:30 AM
Mustang oversteer w/ wheel spacers.... Brad.krieg General Mustang Discussion 0 10-29-2011 12:19 PM
Wheel spacers opinions gregtommy 2011-2014 Mustang GT 49 09-04-2011 09:11 AM
02:16 AM
