car shaking` - Mustang Evolution
Old 12-24-2011, 11:38 AM   #1
Evolution's Avatar
car shaking`
I turned my car on after work and it was shaking really bad at idle, i got out and listened to the exhaust and it was misfiring. My check engine light was on but it has been because i need to replace and 02 sensor. Do you think that could be the problem?
Thanks.
Evolution is offline   Reply With Quote
Old 12-24-2011, 12:34 PM   #2
mystang50's Avatar
Re: car shaking`
Thanks.
my harmonic balancer went out and it shoook jus like it was missing...
Old 12-24-2011, 01:40 PM   #3
Evolution's Avatar
How much are they? And where can I get one?
Old 12-25-2011, 02:24 PM   #4
Justasix98's Avatar
Thanks.
My car was doing the same thing at idle, and my CE light is on also because of the o2 sensors. Run a tank of 91 octane through it, and Lucas Injector Cleaner. It fixed the problem on my 98'.
Just A Sixxer!
Proud member of WickedStangs Okc Chapter!
Justasix98 is offline   Reply With Quote
Old 12-25-2011, 04:13 PM   #5
davidcseifert's Avatar
Region: Arkansas
Re: car shaking`
Which O2 sensors the fronts or the rears?
Rears don't matter, the fronts affect you A/F if they are bad...
blower/new cam soon
Old 12-25-2011, 05:23 PM   #6
Evolution's Avatar
They are the bank 2 sensor
Old 12-25-2011, 06:15 PM   #7
Re: car shaking`
bank 2 is the drivers side. and more than likely it is the front. the rears are pretty much useless. basically they are there for the purpose of knowing if the cats are there or not.
Just a Six
v6procharged is offline   Reply With Quote
Old 12-25-2011, 06:44 PM   #8
Evolution's Avatar
So you think it's my 02?
Old 12-25-2011, 06:48 PM   #9
Re: car shaking`
it's a possibility. could be something to do with not getting spark as well.
Just a Six
Old 12-25-2011, 07:16 PM   #10
austinknoll's Avatar
Check your coil pack. Mine was shot. Replaed it and fixed it right away. My coil pack was so bad it had a dead cylinder an the fuel was getting very little spark. The number 2 cylinder was misfiring an pulled off the wires and found the #2 conductor was black while the rest were like a bronzeish color
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 12-25-2011, 07:40 PM   #11
Evolution's Avatar
How much are coil packs?
---------- Post added at 07:40 PM ---------- Previous post was at 07:40 PM ----------
Cause mine is misfiring aswell.
Old 12-25-2011, 10:17 PM   #12
Re: car shaking`
about 50-60 bucks i think.
Just a Six
Old 12-26-2011, 12:24 AM   #13
At oreillys I got mine for 80 just check it first and check your spark plug wires and spark plugs. Easiest to check is the coil
65 Mustang coupe
Old 12-26-2011, 08:17 AM   #14
Region: Arkansas
Re: car shaking`
If you must replace it get a ford coil pack
blower/new cam soon
Old 12-26-2011, 11:37 AM   #15
Evolution's Avatar
And how do I check if it's ok? Just look at the wiring and look for damage and stuff?
Old 12-26-2011, 12:23 PM   #16
Well you can pull each wire off the coil pack and check for any dead cylinders. It would be obvious which cylinder is dead. On mine, the #2 cylinder was black, not bronzish. If that looks fine you can try checking/ replacing your spark plugs wires and your spark plugs. After months I finally found that my coil went bad. Slapped a new one on and it ran like the day it came off the assembly line
65 Mustang coupe
Old 12-26-2011, 04:38 PM   #17
Re: car shaking`
you can pull off the boot and see if it is getting spark (be careful not to get shocked)
Just a Six
Old 12-26-2011, 09:04 PM   #18
mystang50's Avatar
Re: car shaking`
yeah its a nice tickle if u do...lol
Old 12-26-2011, 09:10 PM   #19
Re: car shaking`
no joke
Just a Six
Old 12-26-2011, 10:24 PM   #20
Region: Arkansas
Re: car shaking`
I usually just run my hands down the wires whenever it misfires, always first test, no point in waiting til night time to look for sparks lol
It's not that big of a jolt....
blower/new cam soon
Old 12-27-2011, 06:05 AM   #21
Re: car shaking`
you dont have to wait til night time to check for spark.
Just a Six
Old 12-27-2011, 08:21 AM   #22
Region: Arkansas
Re: car shaking`
Well that or have a garage to hide from the light in.... I guess if you thought you just had to do it now (visually) you could throw a tarp over it or something haha
blower/new cam soon
Old 12-27-2011, 12:53 PM   #23
mystang50's Avatar
But u don't wanna hide tha beauty!! Lol
How To: Plasti Dip Your Car (In Depth, 6 pages worth of Microsoft Word) Topless04GT Mustang Paint, Appearance & Detailing 318 05-17-2017 12:40 PM
Thoughts on my next car.. Dubya11 General Car Discussion 23 12-10-2011 05:33 PM
Dream Car? JetWolf General Car Discussion 105 12-08-2011 11:29 AM
Car show in Queen Creek, AZ Loraco Regional Mustang Discussion 1 12-07-2011 10:58 AM
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
09:41 AM
