98 v6 mustang electrical probs - Mustang Evolution
Old 12-24-2011, 06:53 PM   #1
insomniac717's Avatar
My v6 98 mustang has an after market head unit and had it in for a good 6 months no problems except now when I turn of my car it stays on and now it doesn't turn on at all and my remote clicker doesn't unlock or lock my car and when I unlock my car from inside my head lights turn on and my speedometer doesn't work
insomniac717 is offline   Reply With Quote
Old 12-24-2011, 07:23 PM   #2
Justasix98's Avatar
Pull out the head unit, and check all the wiring. Every inch of it. And your headlights/head unit/speedo not coming on problem, check the fuseblock under the dash on the far left side. I remember when I hooked mine up (I had to re-wire literally everything, and I mean everything) my car wouldn't start, not even turn over. Checked all my wiring, replaced the fuse and bam, problem solved. The head unit had a bad ignition wire, causing it to arc out and pop the fuse. Btw I own a 98' as well.
Just A Sixxer!
Proud member of WickedStangs Okc Chapter!
Justasix98 is offline   Reply With Quote
Old 12-26-2011, 09:27 PM   #3
Okay you were right about the fuse but my head unit still doesn't turn off and my speakers turn on and off
Old 12-26-2011, 11:11 PM   #4
Justasix98's Avatar
Your head unit not turning on/off. Pull out the head unit. From the car harness, there's a solid red wire (+ constant power) and a solid yellow wire (+ ignition). Reverse these 2 wires going to the head unit. That should fix the problem.
Glad I can help..
Just A Sixxer!
v6 mustang
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
05:48 AM
