Knocking in left front - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 11-01-2007, 01:34 PM   #1
fasternu_674 is unknown around these parts
Ok guys I was driving my car the other day and every time I turn right I hear a click click click........... until i start going straight again. I got underneath the car and checked to be sure everything was tight and it was. I am stumped on this. Can anyone help me out? Thanks.
fasternu_674 is offline
Old 11-01-2007, 05:25 PM   #2
Terminator Owner
SpectorV is just getting started.
Re: Knocking in left front
where does the noise come from the front or rear? Do you have after market rims/tires or wider than stock?
SpectorV is online now
Old 11-01-2007, 07:07 PM   #3
it is coming from the front and yes I do have after market wheels and tires and both are wider than stock but I had never noticed it before. It just started and I have had them on for about 3 months.
Old 11-01-2007, 07:24 PM   #4
Kyle is unknown around these parts
dont turn..........go straight everywhere.
might be a power steering issue of some sort
Kyle is offline
Old 11-01-2007, 07:33 PM   #5
if it was power steering why would it do it only when I turned right? I didn't think about it but it may have been because I had a carload of guys. That may have caused the clicking due to the over width tires plus the extra weight on the suspension. I haven't driven it since then. Hopefully it won't start up again when I head home tomorrow. If you have anymore ideas let me know. Thanks
Old 11-01-2007, 07:43 PM   #6
DarkShadow's Avatar
DarkShadow is unknown around these parts
Send a message via AIM to DarkShadow
Tie rod ends perhaps?
DarkShadow is offline
Old 11-01-2007, 07:48 PM   #7
What is the best way to check those? I got under the car and was pulling and pushing on everything making sure everything was solid. I didn't think about it until now should I have jacked up the front end to take all the weight off then checked everything?
Old 11-02-2007, 06:56 AM   #8
Terminator Owner
when I had 17x9 wide rims with 275/40/17 tires on my 97 and 01 if I turned to tight I would bump the front sway bar and make such a noise. You can turn the wheel all the way and see if it touches or is very close to anything~ remember while turning there is more force on the side your turning from if you are going a modest speed so the car will be lower on that side as well.
the backspacing of the rims also plays a role in if it will rub, my 17x9s had a 5.95 backspacing.
Old 11-02-2007, 09:28 PM   #9
Kiljosh's Avatar
Kiljosh is unknown around these parts
Jack the front end up and pull on the tires. If they move, theres your problem.
Kiljosh is offline
Old 11-04-2007, 06:20 PM   #10
well I drove it 100 miles home this weekend no problems at all. I think it was just the combination of the weight and my aggressive driving. Thanks for your help.
Closed Thread
« Vs. CRX | gears »
Engine Knocking NotoriousSPG Pre-2005 V6 Mustang 10 07-08-2010 04:42 PM
Knocking noise Foxone General Mustang Discussion 6 10-28-2009 10:38 PM
05 GT front end knocking noise texastosh 2005-2009 Mustang GT 2 09-01-2007 01:57 PM
Knocking 3.8 Skip Fix Pre-2005 V6 Mustang 5 03-31-2007 09:26 PM
Knocking engine Black Panther Pre-2005 V6 Mustang 25 11-02-2004 06:57 PM
10:40 AM
