check engine light - Mustang Evolution
Old 01-03-2012, 12:00 PM   #1
kickerofdoom's Avatar
check engine light
I got two codes p1401 and p0174
Old 01-03-2012, 12:04 PM   #2
Re: check engine light
aux emissions control & system two lean (bank 2)...both codes can be for the same issue...which is looking like an upstream o2
SonicBoom239 is offline   Reply With Quote
Old 01-03-2012, 12:15 PM   #3
I have had the lean banks for awhile. One time it was the wire came off the spark plug. The car runs fine but I think you could be right should I only change one or both
Old 01-04-2012, 02:30 AM   #4
-Clean the MAF sensor
-Seafoam the upper intake manifold
-Accidentally pulled out my pcv valve last week and got the same code.
-Check for tiny vacuum leaks around EGR & vicinity.
These suggestions have eliminated the same code for me once or twice over the last 5 years or so. Might be the culprit, might not. Just hope that it might help you out. Good luck.
check engine
9000 miles and the check engine light comes on??? NJFilly 2011-2014 Mustang GT 2 12-15-2011 09:51 PM
Check engine light? galindojr24 2005-2010 Mustang GT 42 08-30-2011 07:34 PM
having trouble help check engine light keeps coming on for the same code mustangsally696 General Car Discussion 2 08-18-2011 07:02 AM
Check engine light big horse 91 2011-2014 V6 Mustang 3 07-18-2011 01:55 PM
'88 GT check engine light? robert81717 1979-1995 Mustang GT 7 07-12-2011 11:56 PM
05:50 PM
