Problems - Mustang Evolution
Old 01-05-2012, 02:17 AM   #1
Evolution's Avatar
Problems
I have been having misfirings with my car, it shakes when I start it(only for a little bit then it stops) also today I went to turn it on and it would start then slowly die down till the engine shut off, it seemed as if it's not getting enough spark. I'm thinking it's spark plugs or something to do with the coil pack. I had to give it gas to start it while I turned it on, I reved it afterwards and my exhaust was making a crackle noise. I have a stock exhaust so I'm not sure why, it sounded cool but I'm not sure thats a good thing. I need a 02 sensor(bank 2) I know that for sure. Any other help would be greatly appreciated!!!
Evolution is offline   Reply With Quote
Old 01-05-2012, 02:41 AM   #2
KM98Stang's Avatar
Check altinator, battery terminals, spark plugs, could even be a vacuum leak so check if all your hoses are connected.... injectors might have a little build up aswell... if all that fails you could have a fuel pump problem
KM98Stang is offline   Reply With Quote
Old 01-05-2012, 02:49 AM   #3
Evolution's Avatar
My alternator squeaks really bad at times and I also had a code for the evaporative emissions valve system which I haven't got time to fix yet. And I am leaking oil, not sure where it's coming from.
Old 01-05-2012, 02:52 AM   #4
KM98Stang's Avatar
Pray you don't have a cracked block :/ but might need a new head gasket depending on the spot of the leak. Advanced Auto Parts will check your alternater for free...
Old 01-05-2012, 03:07 AM   #5
blackhawk 1's Avatar
Re: Problems
start saving for a new one
blackhawk 1 is offline   Reply With Quote
Old 01-05-2012, 11:42 AM   #6
Evolution's Avatar
More than likely what do you think my engine starting problem is? Would it have anything to do with my oil leak?
Old 01-05-2012, 08:57 PM   #7
Re: Problems
Oil leak unrelated unless so much it's causing electrical problems. Fix what you're sure of. If O2 problem, computer may compensate for bad info, worsening the effect. I would evaluate entire vehicle and make sure it's worth saving. I've replaced engines in cars that i liked and overall condition warranted. I've junked some that were needing to much to be a deal.
earthdeth is offline   Reply With Quote
Old 01-05-2012, 09:07 PM   #8
Evolution's Avatar
You think that the vehicle may not be worth keeping?
Old 01-05-2012, 09:22 PM   #9
Re: Problems
Can't say without much more info. Just an oil leak can be a loose piece or catastrophic failure. If you do it yourself cost difference alone can be determining factor.
Old 01-05-2012, 09:24 PM   #10
Evolution's Avatar
Would it come up on a diagnostic machine where the leak is coming from?
Old 01-05-2012, 09:38 PM   #11
Re: Problems
If it's affecting the way something works, yes. IMO a computer diagnostic is some of the best money you can spend if it saves you a lot of diagnostic part-changing. If a shop tells you what's wrong you can still fix yourself. Before i had much experience i had 76 volare that I changed many, many parts on. I had old dist cap that I used. Still no good. Took to shop. Mech calls and says dist cap, $60. I said go ahead. Figured he'd see his error. he called again and said needs timing adjusted, $60. To turn dist? I told him he was done, grabbed my timing light and went. Paid him. Started car. Knew I was right. Adjusted timing. Ran like a dream. Best $100 I ever spent.
Old 01-05-2012, 09:43 PM   #12
Evolution's Avatar
So I would be best off getting it to a shop and running it through a diagnostic machine before I replace stuff that I'm not sure is causing a problem..
Old 01-05-2012, 10:04 PM   #13
Re: Problems
I think so. Replacing parts can get pricey & then you have a bucket full of good(?) used parts. If it cranks it's not battery and i would rule out charging, cooling systems. Get a manual & get troubleshooting.
2000 V6 problems iphonemaster93 2.3 Mustang 47 01-12-2012 12:10 AM
Misfiring problems Stockish302 1979-1995 Mustang GT 14 11-15-2011 01:08 PM
Self installing the boss 302 mani! Any advice or problems anyone has run into? Benzo 2011-2014 Mustang GT 6 10-03-2011 05:23 PM
Different Starting Problems milkrun49 2011-2014 Mustang GT 3 07-15-2011 02:19 PM
02:06 AM
