Shift points - Mustang Evolution
Old 01-06-2012, 07:53 AM   #1
Fordhartbreaker's Avatar
Shift points
Hey buds just wandering in ur five speeds at the strip were do u guys shift mine won't go from 1st to 2nd any higher than 4 grand and it has a brand new clutch can I not drive or what's up pls tell me when u shift so I can learn and get better?
Fordhartbreaker is offline   Reply With Quote
Old 01-06-2012, 07:55 AM   #2
TaylorF25's Avatar
I have a stock clutch in mine that was replaced but I can shift at around 4900 before it starts to slip. Granted that I don't suggest red lining your car or pushing your tranny to its limits.
TaylorF25 is offline   Reply With Quote
Old 01-06-2012, 07:56 AM   #3
No I'm not trying to but when I do go to 2nd all it does is grind only done it twice bc it scares me
Old 01-06-2012, 08:04 AM   #4
TaylorF25's Avatar
As long as you don't try to force the car into second it shouldn't grind. Grinding could be caused by many things but most of the time it is driver error.(not saying your a bad driver,but it happens to all of us) your problem sounds mechanical though. I would check to make sure your whole tranny is aligned as well as your clutch,pressure plate,shifter,etc... also make sure that you don't have any broken teeth on the pressure plate
Old 01-06-2012, 10:19 AM   #5
V6 stang's Avatar
I shift at 6k (I think that's the one before the red )
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 01-06-2012, 11:03 AM   #6
How do u check to see if ur tranny is aligned properly?
Old 01-06-2012, 11:39 AM   #7
TaylorF25's Avatar
If you have a mechanic as a friend I would just let him throw it up on the lift and he can tell. If not its a little more difficult but you can visually tell if something isn't lined up correctly
Old 01-06-2012, 07:00 PM   #8
Ok cool and for the shift points were do u guys shift Rpms wise all the way to 5th
Old 01-06-2012, 07:03 PM   #9
TaylorF25's Avatar
Normally around 3k when I'm driving normally, and I don't use 5th very much
Old 01-06-2012, 07:53 PM   #10
I mean at the strip were do u guys shift
Old 01-06-2012, 08:17 PM   #11
V6 stang's Avatar
I shift right before the red.. But I'm not exactly a pro drag racer lol
Roush Exhaust
Old 01-06-2012, 09:43 PM   #12
Neither am I lol
Old 01-08-2012, 03:32 PM   #13
Re: Shift points
mY 04 auto I had a tune set for 6k shifts. Redline is what ? I cant rememer lol
5800 should probably be your limit though.
---------- Post added at 04:32 PM ---------- Previous post was at 04:31 PM ----------
But **** if I was a 5 speed at the track, after I launch I wouldn't let off the gas till I was across the finish line
SenorMike is offline   Reply With Quote
Old 01-08-2012, 05:03 PM   #14
Well when it gets to ab 4500 the clutch feels like I'm stepping on a paper bag to although ik it's a new clutch I have the papers from the dealer where I bought it
Old 01-08-2012, 05:06 PM   #15
TaylorF25's Avatar
I would take it to them and have them look at it
Shift knobs ThePhantom 1996-2004 Mustang GT 11 12-24-2011 04:30 PM
Lift points pcarman 2011-2014 Mustang GT 5 11-07-2011 03:00 PM
Black Shift Knob skyline247 2011-2014 Mustang GT 13 09-07-2011 11:06 AM
Shift kit Jesse Bach General Car Discussion 1 08-21-2011 02:17 AM
Shift knob problem with steeda tri-ax apex32 2011-2014 Mustang GT 5 06-29-2011 01:04 PM
08:10 PM
