P and P vs Extrude honing - Mustang Evolution
Old 11-03-2003, 06:36 PM   #1
Send a message via AIM to ASSEMbler
anyone get their manifold extrude honed? Would I get better results than a P and P job? Extrude has proven 20% more airflow.
I suppose getting a p&p manifold then extrude honed would be best.
ASSEMbler is offline   Reply With Quote
Old 11-03-2003, 06:52 PM   #2
why do both? if you wanted it honed get it honed, dont pay for portin gand then get it honed.
I dont think youd see any worthwhile gains on an N/A car unless you had a 4.2/3 beast.
I *could* see it worthwhile on a blown app. but I dont think any v6 has done it yet.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 11-03-2003, 06:57 PM   #3
Monkey's Avatar
dont port first. extrude honing gets it ported enough. next, only extrude the upper if you want. its very expensive, plus the stock upper flows well enough. you would see like 5-7rwhp total on an extrude honed job.
get a good ported lower and heads, and those will get you more gains
Old 11-07-2003, 01:39 PM   #4
RGR
Send a message via AIM to RGR
They way I do it:
If a customer wants Extrude Hone, I will do that for them and
do my hand porting extras for the same price it would cost
from them, ($480) and you would have an RGR spec/Ex. Hone
upper that had more hand porting than Extrude hone does and
RGR specs on the rest of it. I have done it, but we had them hone
it again cuz the long runners were NOT very well done, not even as
good as hand porting so the re-did it no charge. I also did the first
94-98 upper thru them, it came out geat the first time. The customer
did not get dyno results AFAIK, (for the 99) but the 98 guy said it really
helped ALOT over a stock upper! He was quite pleased, it was the only mod
in his comparison, definite gain on the Butt-Dyno He said it felt like
15-20 HP... who knows?
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 11-09-2003, 06:51 AM   #5
Danger Dude's Avatar
Was this BUTT DYNO Calibrated !!!!!!
Old 11-10-2003, 05:34 AM   #6
RGR
only to the baseline run
Old 11-10-2003, 05:38 AM   #7
Old 12-03-2003, 04:00 PM   #8
RGR
So EH + Hand porting is the ticket.
If U get EH thru me I add in the hand porting
no extra charge. It's just as if I worked there
and did the proper porting then EH'ed it!
Old 12-05-2003, 08:37 PM   #9
Sheet metal intake
Sheet metal split port intake plenum available yet through you?
SIG REMOVED FOR THE PRUDE
Old 12-05-2003, 08:38 PM   #10
You bid on that nice 3.8 plenum on ebay right , rgr? It's only for the cougar, right?
Old 12-06-2003, 12:25 PM   #11
RGR
yeah, I think i got it for their asking price
Old 12-08-2003, 07:06 PM   #12
That's a nice intake.
What would happen if you took a 2000+ intake and put big cylindrical
chambers on the sides like that intake? It looked like a realy good intake.
Old 12-09-2003, 04:26 AM   #13
RGR
I have something like that in the works,
taller and straighter than stock, bigger plenums.
I hav not figured the TB setup yet...
Old 12-10-2003, 06:16 PM   #14
manifold
Larger TB
I was looking at that cougar head, and I thought "ram air".
BTW you have a split port p&p ready to go? I've been trying to get an extra core for you, I can get a non split for you off ebay, but I don't know if you care which type you get back. I'd like to get it powedercoat too, don't know if you do gold powdercoat. I have a 2000 in the gold, and I figured it'd be pimp to have a gold manifold.
Old 12-10-2003, 07:00 PM   #15
RGR
I gots a shiny SPI upper, mostly polished, needs ported, but of course you have
a take-off manifold that would be the core. I need same type back, unless
someone with single port want to send splitters as cores
I can get gold powdercoat, but it's gonna be $200 more than just the porting...
if we want to do a GP on gold powdercoat I can reduce the price some.
Get a whole rack and I can do it for 100 each, but that would be like
12 people or more... well, maybe I can do it with less, ask around!
I have an industrial powdercoat shop I deal with, I'll make a post on
Gen board I guess. If U are really interested! Actually, here is best,
it is for engine parts so engine board is fine.
Old 12-11-2003, 11:04 PM   #16
Awesome. I just had back surgery done, and it's snowing. I will have to see when I can get it off the car. It sounds easy changing the gaskets and sending the core back, but on a hill, in the winter...
If you have phenolics too, and the bolts I need I would do that too.
The correct bolt length is what scares me, I hear all sorts of people not finding the right bolts.
I'm going to start selling some extra stuff and get ready to do this.
This is going to be so much fun.
Can you do a custom RGR manifold badging?
Old 12-12-2003, 10:11 AM   #17
RGR
I was thinking of that for my post-removed SPI uppers...
I put a plate over the holes instead of welding in plugs
11:06 AM
