short throw install - Mustang Evolution
Old 01-06-2012, 07:55 PM   #1
97V6stangct's Avatar
short throw install
How easy is it to install a short throw shifter I have a 1997 v6
97V6stangct is offline   Reply With Quote
Old 01-06-2012, 09:47 PM   #2
Re: short throw install
do you have 15 minutes?
SonicBoom239 is offline   Reply With Quote
Old 01-06-2012, 10:16 PM   #3
ColeJohnson's Avatar
+1 It may take a little longer than that at first to get all the bolts unless you have the correct tools. Took me a good hour just because I did other stuff as well and took my time and used RTV sealant. Blah blah, but it's easy and quick and the best mod you'll do for drivability.
2016 Comp Orange GT (current)
Old 01-07-2012, 12:36 AM   #4
hell while you're doing it might wanna go ahead and flush and fill the trans with fresh fluid and syncromesh...might as well since you'll have the shifter off, and i bet you're car would be happy with it
Old 01-07-2012, 07:25 PM   #5
TaylorF25's Avatar
I've heard that a short shifter can screw up the syncros in the tranny if you don't adjust them? I'm not sure because I've only heard of this. Can anyone either confirm or deny this for me?
TaylorF25 is offline   Reply With Quote
Old 01-07-2012, 07:28 PM   #6
aegischief's Avatar
Never heard that. Just make sure that you set the shift lever stops.
aegischief is offline   Reply With Quote
Old 01-07-2012, 07:30 PM   #7
TaylorF25's Avatar
And how is that done exactly?
Old 01-07-2012, 07:36 PM   #8
aegischief's Avatar
There should be 2 bolts on the outside of the shifter, one on top for first and third, another on the bottom for second and fourth. Once the shifter is install, put it in third and then screw the bolt till it is just from touching the shift lever. Do the same thing with the tranny in second. Once set, tighten the backer nuts to keep it from backing out. These stoppers prevent you from damaging the shift forks in the tranny during hard 1-2 and 2-3 shifting.
Old 01-07-2012, 07:40 PM   #9
TaylorF25's Avatar
Thanks for that, appreciate it
Old 01-07-2012, 11:12 PM   #10
yep...
Old 01-08-2012, 03:38 AM   #11
blackhawk 1's Avatar
love my short throw Hurst
blackhawk 1 is offline   Reply With Quote
MGW Short Throw Shifter avengnd 2011-2014 Mustang GT 48 11-29-2011 10:23 PM
Steeda Tri ax short shifter install..... rinfield2004 SVT Mustang 10 09-02-2011 12:40 AM
short throw shorter.. fordgirl1209 Pre-2005 V6 Mustang 11 08-23-2011 04:23 AM
WTB/ short throw shifter 93stang306 Mustang Parts for Sale and Wanted 0 06-25-2011 08:10 PM
06:28 AM
