Engine dissasemble - Mustang Evolution
Old 01-10-2012, 08:26 AM   #1
Evolution's Avatar
Engine dissasemble
So I am disassembling my engine for head gasket replacement, I thought this may be a good time for some performance parts since ive got the engine apart. Anyone have some good ideas I may be able to do?
Evolution is offline   Reply With Quote
Old 01-10-2012, 09:23 AM   #2
kickerofdoom's Avatar
Windstar
Old 01-10-2012, 12:33 PM   #3
Re: Engine dissasemble
P&P heads and lower intake
Windstar upper intake
Custom cam and spring/retainers
UDP
Long tubes - Full O/R exhaust
Or even pull the engine and get a 4.2 from an f150 or find some high compression pistons
SenorMike is offline   Reply With Quote
Old 01-10-2012, 12:50 PM   #4
ESG642T's Avatar
Potential Ideas.
1) split port swap?
2) ported and polished heads and intakes
3) camshaft
4) you could do a 4.2 short block swap if you found one cheap enough but then I wouldn't do this without doing #2 unless you just had high mileage and found a low mileage 4.2
5) mikes idea with the pistons but that one will get expensive.
Things that don't belong on a Mustang: 20+" wheels, altezza lights, halo headlights, neon underglow, body kits that don't come from saleen or roush.
ESG642T is offline   Reply With Quote
Old 01-10-2012, 12:57 PM   #5
yea, P&P heads and ported intakes along with a nice cam would work great~ but it can get costly.
Old 01-10-2012, 01:01 PM   #6
Originally Posted by ESG642T View Post
Potential Ideas.
1) split port swap?
3) camshaft
fogot shu twasnt uh split poht. so either do the swap or no windstar or power.
F it. M90 swap
Old 01-10-2012, 01:34 PM   #7
Evolution's Avatar
Those are all fairly expensive though aren't they?
Old 01-10-2012, 02:51 PM   #8
its a ton of hassle to go split port swap, I would p&p heads/intakes and get a cam or just put it back to stock
Old 01-10-2012, 02:57 PM   #9
OP i tell you what, since I seriously doubt you'd go with an M90 swap lol
I say you buy my spare cam off me, you'll need some ls srings and GT retainers, and you might end up needing new Push Rods.
« Superchip | Clutch »
Myths about "back-pressure" Eturner General Mustang Discussion 45 09-08-2016 01:31 PM
Engine seized! 2012 gt 5.0 8WOOD 2011-2014 Mustang GT 94 12-01-2011 12:39 AM
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
12:59 AM
