Air vent problem.Help! - Mustang Evolution
Old 11-08-2007, 04:13 PM   #1
I have a problem with a 1994 mustang with the air vents in the car. It only blows the air through the floor and defrost setting and not the vent setting when switched to it. Any ideas what the problems is? Thanks.
fordguy5.0 is offline   Reply With Quote
Old 11-08-2007, 04:50 PM   #2
MonteCitan's Avatar
Re: Air vent problem.Help!
Check the condition of the vacuum lines at the selector switch (pull the dash faceplate off, and from there its 2-4 screws..) That's a good place to start... I don't have a vacuum diagram with me but if you pull the connector out for the vacuum lines, you should have a black one with vacuum when the engine's on...... it could just be a switch...
While your in there see what you can see, listen around for any vacuum leaks... check the vacuum lines under the hood
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 12-03-2007, 10:58 AM   #3
Your Mustang May Be Like My 96 Mine Would Only Blow Own The Defrost No Matter What Setting You Had It Own. The Vacuum Pump Is Under Te Passenger Side Dash. Just Take The Glove Box Out Really Easy And You Will Be Able To See If There Are Mssing Wires Dont Go Shoving Through All The Wires And Disconnect Any But Mine I Just Say Where It Came Unplugged And Plugged It Back Up And Electric Taped It. Really Simple But If It Works Then Your Vacuum Pump Just Isnt Sending It To The Right Pplace Which Is A Lose Wire. Somewhere.
customsixstang is offline   Reply With Quote
Side VEnt install Foxone General Mustang Discussion 8 09-26-2009 01:24 PM
Air Conditioning problem - 96 Mustang V6 WVKarenC 1996-2004 Mustang GT 8 06-15-2009 12:42 AM
weatherstrip vent window DAC Classic Mustangs 3 02-24-2009 05:49 PM
Random Vent..Grrrr ChickStang02 The Bar 18 03-27-2007 04:20 PM
03:04 AM
